i have a 05 se and i will like to know can i just change the wheel bearings or it is a hub with the bearing in it thanks
05 cool vanilla se led tails lights hids head lights rt 35% tints rims fog lights.wifes car 06 sxt silver hids
DESCRIPTION
The front wheel bearing and wheel hub of this vehicle are a one piece sealed unit or hub and bearing unit type assembly.
On All-Wheel-Drive (AWD) vehicles, the hub and bearing (1) is mounted to the knuckle using four mounting bolts and to the axle half shaft using a retaining nut. The center of the AWD hub and bearing is splined to match the outer joint of the axle half shaft.
On Rear-Wheel-Drive (RWD) vehicles, the hub and bearing (1) is mounted to the center of the spindle using a retaining nut.
All front hub and bearings have five wheel mounting studs (3) on the hub flange for mounting the wheel to the vehicle. The wheel mounting studs are the only replaceable components of the hub and bearing. Otherwise, the hub and bearing is serviced only as a complete assembly.
On RWD vehicles, a magnetic encoder (2) for the wheel speed sensor is pressed onto the hub and bearing. A magnetic encoder is not located on the AWD hub and bearing. It is pressed onto the axle half shaft outer joint.
thanks any one knows whow has them for a good price thanks
