Results 1 to 5 of 5
    JonzMgnm's Avatar
    Jan 2006
    Commack, New York
    Magnum door speakers
    I'll be changing the door speakers on the Maggie tomorrow so is there anything I should know about removing the door panels before I "break" something? I searched the knowledge base without any luck so thanks in advance everybody.
    John Y
    ratman1648's Avatar
    ratman1648 is offline Dude, Where's my LX!?!?
    Portland, Tx
    plastic clips along the top are a pain in the a$$
    She will always be missed
    ^^^Somewhere in Houston^^^
    robbyho's Avatar
    robbyho is offline the curiously strong robbyho
    Dec 2005
    Milford, CT
    Yes! The grey circle clips that are on both sides of the door come undone by pushing the center pin in and then pulling them out. The Black clips don't have to be undone b/c they are part of the window molding.
    Other than that there are a few clips on inside of the top of the door, a screw by the handle, a screw farther down, and 3-4 screws along the bottom.
    Rob
    fnkychkn's Avatar
    greasy cardboard box
    from FSM
    1. Unsnap and fold back the screw cap below the trim panel pull handle to access and remove the screw that secures the panel to the pull handle bracket.
    2. Unsnap and fold back the screw cap within the interior remote handle recess of the trim panel to access and remove the screw that secures the panel to the inside of the door. The screw cap on the sedan opens from the top, and the wagon opens from the bottom.
    3. Remove the four screws that secure the bottom and front lower corner of the trim panel to the inside of the door.
    4. Remove the two push pins at the rear of the trim panel and one push pin at the front edge of the trim panel.
    5. Pull the trim panel away from the inside of the door far enough to disengage the locator pins near the top of the panel from the door, then lift the rear of the panel upward far enough to disengage the interior door latch lock link and knob from the clearance hole at the upper rear corner of the panel.
    6. Reach between the top of the trim panel and the inside of the door shell to unsnap the plastic clip that secures the end of the interior door handle latch release link to the handle lever and disengage the link from the handle.
    7. Pull the trim panel away from the inside of the door shell far enough to access and disconnect the door wire harness connectors from the power window/lock/mirror switches, the door module, and the door courtesy lamp as the vehicle is equipped.
    8. Disengage the retainers that secure the door wire harness to the inside of the trim panel.
    9. Remove the trim panel from the inside of the door.
    JamminWagon's Avatar
    Cheyenne, WY
    Here is the write up I did with pics.
    Door Panel Removal Step by Step - Lots of pics!
