Results 1 to 15 of 16
    RCThunder is offline LX Newbie
    Jun 2004
    The Inferno Red Mystery..
    Ok, I know it has been talked about before. I saw a new Magnum in the new red to me, seeing it on the side of the road, was night and day. Looked more darker - more like maroon.
    All the ads have the Inferno Red and it appears that is gone. Was this a special low production to increase some uniqueness and early value for the lucky ones? Or a messup? I am sure many new buyers want the car in the red in the ads but won't be able to....
    Strange indeed!
    oroblram69 is offline LX Newbie
    Oct 2004
    ,,, or maybe it was cheaper, or maybe the switched companies b/c it was cheaper.
    o_swas is offline LX Newbie
    Jul 2004
    I'm not sure if this is actually true, but here's the story I heard -- can't remember if I heard it FROM bramptonassembly.com or maybe DCX Customer Service....
    Supposedly Inferno Red did not store well for long periods of time, almost as if the paint went "bad" if it wasn't soon applied to a vehicle. Since Inferno Red has a roughly $225 premium, it wasn't as popular as the other colors, and thus wasn't used as fast. Since it wasn't used as fast, some of it would go bad and have to be thrown out. DCX could purchase less paint FROM the supplier (PPG?) but then the paint would cost more due to diminished volume discounts.
    Blaze Red apparently does not have any of these problems, thus the change over to Blaze Red and its supplier (DuPont?).
    dansk is offline LX Padiwan
    The story I have been able to glean FROM varoius posts on 5 different forums is that DC started with the tinted clear coat, which has a short shelf life once it is mixed. When production started and the demand for these cars was over anything they expected, they switched paint suppliers and fell back on the red that they have now. Unfortunately, the communication was not made clear to their outside heated mirror supplier, who paints the mirrors before shipping them to DC. This caused a delay in Red RT's that broke loose just as the RT demand was at it's peak.
    Vaderwagon's Avatar
    Vaderwagon is offline LX Padiwan
    Marengo, Ohio
    They should have offered the car in Flame Red. That would be a more "sporty" performance type color to go along with the colors of the Ram, Viper ETC. Just my $.02 worth.
    Jun 2004
    Good points...
    analyte is offline LX Newbie
    Jul 2004
    Madison, MS
    Some people got bits of it,
    1. Tinted clearcoat has a poor shelf life once loaded INTO a paint system and with Inferno Red only offered on Magnum its percentage of production was too low and the surcharge didn't help.
    2. The automation equipment used at Brampton had issues with incomplete purges in the clearcoat zone. This is turn caused cross contamination of the two clearcoats, tinted and non-tinted.
    3. Repairs were also more difficult since the color is very film build dependent.
    4. The change in colors had NOTHING to do with a change in paint suppliers. We are all able to supply the same colors based on standards provided by the automakers. This change was made due to reasons other than quality, appearance, material issues, or cost.
    All red pigments are more expensive than other colors. The tinted clearcoat added to that cost. Therefore, the color is about the same price regardless of the paint supplier.
    Kerry
    E8502's Avatar
    E8502 is offline The Swiss Cheese
    Feb 2004
    Massachusetts
    Anyone have pictures of the new color so we can see then side by side??
    Chris ~
    '01 LHS • '01 Dakota Sport • '04 Sebring Convertible • '05 Grand Caravan
    Ig-man's Avatar
    Ig-man is offline LX Newbie
    Oct 2004
    No. California
    Quote Originally Posted by analyte
    Kerry
    Very good explanation. You sound like you have good "inside" information.
    AndyK is offline LX Newbie
    Jul 2004
    Kerry
    Thanks for the clear and comprehensive information.
    05MagnumRT's Avatar
    05MagnumRT is offline 1 8 4 3 6 5 7 2
    Dallas (Frisco), TX
    Quote Originally Posted by E8502
    There were a couple of side by side picts posted by Tzar007 in this thread:
    http://www.dodgemagnum.net/phpBB2/vi...ight=blaze+red
    National Sarcasm Association - like we need your support.
    HEMI Registry #174
    Magnum Club #1146
    LXForums #3315
    Cal Jeff is offline LX Newbie
    Jul 2004
    Norttern California
    What were the reasons?
    Kerry
    This sounds like a very good partial explaination. What is lacking is the reason the colors were changed.
    Jul 2004
    Madison, MS
    Re: What were the reasons?
    Quote Originally Posted by Cal Jeff
    Kerry
    uhh....I guess I don't understand your question Jeff. I gave the reasons for the switch, but if you need the definite, true reason for the switch it is:
    All the other reasons could be dealt with as they were/are at other plants. The automation purge issue could not be corrected and the only true way to solve the problem would have been to install newer equipment, a very costly option for a problem with only one color. Therefore, the best answer was to just change the color to something close(opinion based) that could use the same clear as the other colors to avoid the purging issue.
    Hope this helps clear it up...
    Kerry
    OA-5599's Avatar
    OA-5599 is offline Vanishing Point
    Denver, Colorado
    So, stupid question, assume that since this was an equipment issue, the availability of the paint itself should be good, right?
    2005 Magnum R/T; Hemi Registry #178
    Vortech SC, Dynatech Longtubes, Cats, Aeroturbine Exhaust, Body Mods
    Jul 2004
    Norttern California
    I think I get it
    If I get this the tinted clear coat in the Inferno red was the problem DC changed to Blaze Red Crystal Pearl coat. So the question should be if any paint supplier can make any color why change FROM the inferno red part and just switch to the pearl coat
