Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By PRPLHAZE
Thread: hum/droning sound in the rear/driver side wheel
    pantelija is offline LX Padiwan
    Jan 2008
    michigan
    as title.
    when I turn left the sound diapers. Back on stright - it returns. Interestingly it is not more intense when I turn right.
    It is increasing in frequency with the speed of the vehicle. It is not related to engine speed. I rotated the tires and the droning sound stayed. How worried should I be?
    Fritracer is offline LX Newbie
    Apr 2012
    Quote Originally Posted by pantelija View Post
    as title.
    You have a bad wheel bearing/ hub assembly. It needs to be replaced.
    Jan 2008
    michigan
    any ides how much would it cost at dealer?
    how many miles can I survive before fixing it...?
    what is the worse it can happen/
    (i know - questions are stupid, but I would not be asking them if I didnt' have to )
    420guy's Avatar
    420guy is offline LX Padiwan
    May 2012
    Brampton, Ont.
    1- No idea
    2- Who knows 1 day or 1 year
    3- Entire wheel comes off ( hope this is not at highway speeds )
    Jan 2008
    michigan
    thanks.
    Soooo off to stealership I go...
    Quote Originally Posted by 420guy View Post
    1- No idea
    jtut90 is offline LX Newbie
    Oct 2011
    illinois
    Mines been doing that for about 6000 miles, my brother is supposed to look at it but he is a Pansy who refuses to work in the driveway. Guess I'll have to get ahold of somone else. I can't do it myself due to surgery.
    karfreek's Avatar
    karfreek is online now LX Guru
    May 2006
    Fultonville NY (Upstate)
    thanks.
    Can't you find a local independent to do it? Geez, if you go to the dealer walk in backward bent over...
    Jay
    Via Tapatalk
    2011 Dodge Challenger R/T Classic - Redline 3-Coat Pearl, 6-speed
    2005 Dodge Magnum RT-Can you say...HEMI?
    2004 Chrysler Pacifica AWD-Everything but the kitchen sink.
    Montreal300's Avatar
    Montreal300 is offline Go Faster with Class
    Sep 2009
    St. Lazare Quebec
    ^^ Good advise. Bring the vaseline to.
    Pedator, CAI, MDS indicator, ESP/BAS defeat switch, Tranzformer, blacked out wire mesh grille, smoked and flashing side markers, 9005 2400k 65W fogs, Euro rear fogs, debadged and demolded, 255/45/20 Nitto 420's, Boss 338 wheels, painted calipers. Glovebox & cup holder LED Mod. Blastin Bob 6db reso delete pipes. Euro LED side signal repeaters, 55/35 window tint, BT catch can. Color matched tail lights. Custom front lip. LED interior lighting.
    Next: Lower with BCR Coilovers.
    PRPLHAZE's Avatar
    PRPLHAZE is online now 'Scuse me while I kiss the sky
    Dec 2010
    Long Island, NY
    It's really not too bad of a job. What engine? srt axles require you to compress the suspension to remove the hub due to their thickness, but otherwise just jack her up, remove wheel, rotors, calipers(hang out of the way)and hub nut and slowly back out the 4 external torx bolts attaching hub assembly to spindle. Make sure to do a few turns at a time on each one and just pull the hub forward as you loosen them. The same Bolts hold the parking brake backing plate in as well. E12 socket or 12 point 3/8 will work. A swivel comes in handy as well and a long extension. When reinstalling the torque specs are 50ft lbs for hub mounting bolts and 157ft lbs for the hub nut.
    Download the service manual. It's all in there. Section 2 rear suspension hub and bearing New Service Manual Download Link
    DrgnWgn likes this.
    Jan 2008
    michigan
    Thanks all.
    This is what I ordered. Right part?
    2008*Dodge*Magnum*Wheel Hub Assembly Parts from Buy Auto Parts
    Quote Originally Posted by PRPLHAZE View Post
    JCSRT8's Avatar
    JCSRT8 is offline BIG BOY HEMI
    Jan 2009
    ATLANTA,GA
    Funny cause mine had the same symptoms and after the hub change, still there. I really feel it when im turning left and right so im thinking its the struts, IDK.
    mike777's Avatar
    mike777 is offline the square root of 69 is 8 something
    Nov 2010
    MN
    it's always difficult to diagnose 100% the right bearing that is causing the noise. I've been dead certain it was one going bad based on the way it sounded when turning one direction and then the other only to change it and find out it was the other one. Most of the time the "hum" will increase when the bad one is loaded, but not always. If going in to have it replaced play dumb and let the shop/dealership tell you which one is bad and hold them to getting it fixed. Just tell them "I started to hear this sound, but not sure exactly where it is coming from". Then they can drive it and tell you rather than saying "I need my driver's side front replaced" only for them to do what you ask and the problem stays with you having no recourse to get them to correct the actual problem.
    BTW - replaced my driver's side front bearing last weekend using just a floor jack and got it done in less than an hour (1st time ever doing the job too).
    2005 MRT, CV, K&N CAI, 20" Black Powder Coat CSRT OEM Wheels
    Jan 2008
    michigan
    Thanks Mike, good advice...
    SK84's Avatar
    SK84 is online now If it ain't smokin, it ain't broken
    Nov 2011
    Noblesville, IN
    Hey guys, hate to resurrect an old thread but I'm tackling this project this weekend. Looked at the service manual and have tried to find info on youtube but couldn't find it. How big is that hub nut? What size socket am I going to need? Just looking at the back nut, it's going to be pretty stinking big...
    GTP Stage 2 Heads
    Sparrow Cam
    Custom Johan Tune
    Full 6.1 Exhaust
    Catch Can
    180 T-stat
    Eibach Pro Kit
    AAC Rear Wing
