If you are sure you are only going to be gone for 3 months use the Sta-bil in the gas, leave the battery connected and hook up to a battery tender like I use (click here) and you will not have a problem. The engine with a good synthetic oil should not even need anything special done even with storage being a year long. Besure to run the engine a while with the sta-bil in the tank so as to get the sta-bil in all fuel lines & injectors.
For longer then 6 months I would also recommend getting tires off the ground and for year or more draining fuel system should be considered.
Lead, follow, or get the hell out of the way.
'05 MB E320 CDI Alpine White, mine 145 MPH+ & 37 MPG
'91 MB 300D 2.5L Turbo, wife's 117 MPH & 33 MPG
