Results 1 to 6 of 6
    snickle's Avatar
    snickle is offline LX Old Timer
    May 2004
    How do you remove front bumper cover?
    Okay, I probably will breakdown and look in the manual. But I know some of you have.
    I figure out the top clips. The ones along the front of the wheel wells are giving me trouble. I broke one.
    Any quick hints?
    aspendog's Avatar
    aspendog is offline Supporting Vendor
    Dec 2004
    Dallas
    Re: How do you remove front bumber cover?
    Quote Originally Posted by snickle
    Any quick hints?
    They are plastic rivits and are pretty much a one-time use. After removing these there is a 10mm inside the well on each side, then there are a series of 7mm bolts under the car. It will come off after all these are removed.
    LtlDad's Avatar
    LtlDad is offline LX Padiwan
    Nov 2004
    OC, CA
    Try this, I just finished installing my grille and attempted to write a 'how to':
    http://www.dicksdwelling.com/TRex%20...0Install_1.htm
    SoCal_Magnum's Avatar
    SoCal_Magnum is offline LX Venerator
    Los Angeles, CA
    Very nice How-To Ltl...
    Man's biggest mistake is to believe that he's working for someone else.
    DMAG's Avatar
    DMAG is offline This Space for Sale ... Cheap
    Feb 2004
    New Yawk
    LtlDad....would you mind if we added your wonderful How To to our Knowledge Base? I think this would help out the members greatly.
    Thanks alot.
    Anthony
    Follow Me on Twitter! | Knowledge Base | Search | LXOM Winners
    LtlDad's Avatar
    Nov 2004
    OC, CA
    No problem.
    2005 Mineral Gray SXT
    HAS SOME STUFF...
