Hi folks,
Is there anything special to separating the cloth cover from the headrest foam? There seems to be a seam on the underside of the cover but not sure how it's attached around the foam and I don't want to damage it trying to get it off.
Any advice/knowledge that you can share?
Thanks in advance.
300SRT rear spoiler / T Kutz Custom sill plates, ABS cover and firewall cover / emblems by Nate @ ReBadge / BT bling & catch can / braided line here & there / Grant Revolution steering wheel w/ AMG paddle shifters & TRS300's wireless shift controller / 22" Boss 337's / Extreme Dimensions front spoiler / V6 custom tune by Overkill / JBA shorties / SOLO cat-back exhaust / SRT sways / Stoptech SS brake lines / Street Edge coilovers /LMI true CAI (Ralph Gilles Edition)
just peel them off. use a grocery store produce plastic bag over the foam to ease installation.
Thanks Pete, I'll give it a whirl. It seems like the seam has plastic or something hard under it on both sides of the seam. I thought the two sides might be joined together via a locking ridge in the plastic pieces but doesn't seem to be the case.
although i've never had to remove one from an LX, other chrysler vehicles use J-hooks (locking ridge) or zippers.
I have been researching this extensively. I am to reupholster my SRT seats i bought with some other covers. The hard parts u feel are just 2 plastic "Ridges" and they just clip together. The car companies no longer use hog rings and crazy tools to get the covers on. If u grab ur backseat and pull up on it, it will come right off. Its not even bolted down, it sits in a little groove on each side, and u can see all the plastic clips holding the cover on. So all in all its all plastic and zippers. For the headrests though hes right use a part of a plastic bag to get them on, they are a bitch. The seat backs are easy cause u can roll them inside out and roll em on. Good luck.
Go here:
Index of /~goldsmi/Magnum Katzkins
Take a look at 2172 thru 2177, might help.
Thread titles that contain 'OMG' or 'WTF' are not read.
The word is spelled 'Definitely'.
There is a Y and an O in the word 'you'. 2 is not a word.
Learn how to use 'to', 'too', and 'two'. Learn how to use 'there', 'their', and 'they're'.
The things that stop your car are 'brakes'.
Tires are mounted on wheels, A toilet bowl has a rim.
It's only 'old school' if you are 12 years old - in which case it is past your bed time.
You are probably not the first person to ever have that problem - use the Search function, then use it again.
I don't care what you think of my car, I like it just fine.
