Results 1 to 7 of 7
    mac424's Avatar
    mac424 is offline LX Padiwan
    Apr 2008
    Pittsburgh, PA
    Guages shut down
    I was driving to work today in my 06 RT AWD with the cruise control on. Clippin along at about 65. I started to come up on some traffic and was kinda pinched in so i pushed forward on the cruise control knob to cancel my speed and next thing I know all my speedo, temp, tach and fuel guage all went to zero. I thought the car shut off, but no, I hit the gas and it was still goin. Then all the guages come back on. Then went back off. It did about six times. Finally they stayed on and then the ESP/BAS light stayed on. I got to work and restarted the car and the ESP/BAS light is off. Like nothing ever happened. Any idea what this is? Sorry this is so long.
    2006 Dodge Magnum R/T AWD
    Magnesium Pearlcoat
    Mods: 20" Foose DF-5's, Intake and Blastin Bob's 9b Resonator Elim kit, Diablo Tuner, AAC Interior LED Light conversion, AAC LED Fogs, Danko Chin Spoiler (Shaved 1.25"), Mopar iPod Interface.
    Polish Don's Avatar
    Polish Don is offline LX Padiwan
    Jun 2008
    Livonia, MI
    Well,
    My '07 Magnum SXT did something very similar about a month or so ago. The gauges woud either die or freeze in position (i.e. I'm showing 40mph at a dead stop). I took it to the dealer and they told me that the gauge cluser was bad, and replaced under warranty.
    2007 Dodge Magnum SXT - 3.5L V6 with Mopar CAI and Diablo Preditor Tune.
    and a true classic:
    1975 Dodge Coronet Crestwood Wagon
    mac424's Avatar
    Apr 2008
    Pittsburgh, PA
    Hmm well I hope the gauge cluster isn't bad. Everything is still under warranty so i'm not worried. Still kinda scary. I gotta take it in for the AWD shudder so I might as well add one more thing to the list.
    Magnesium Pearlcoat
    CBM911's Avatar
    CBM911 is offline LX Newbie
    Dec 2007
    L.A.
    i jst had the same problem. take it to the dealer and have the check the battery and the battery wires. that should be what is causing it
    mac424's Avatar
    Apr 2008
    Pittsburgh, PA
    But if its the battery cable and or batter wires, the whole car would have had the intermittant problem, right? Everything else still functioned (radio was on and the car was still accelerating). I'll give the battery and cables a check. No need to go to the dealer to check on that stuff. I still think there might be something else though.
    Magnesium Pearlcoat
    mac424's Avatar
    Apr 2008
    Pittsburgh, PA
    Ok, I went out and did the key trick to display the diagnostic codes. The only code that came up was U110A. Anyone know what the code is? I did a quick search and couldn't find anything.
    Magnesium Pearlcoat
    mac424's Avatar
    Apr 2008
    Pittsburgh, PA
    Found this on the forum from FNKY:
    U110A-LOST COMMUNICATION WITH SCM - CAN-C
    • When Monitored: With the ignition on, battery voltage between 9 and 16 volts, and engine run time greater than 3 seconds.
    • Set Condition: The PCM doesn't receive a bus message from the Steering Control Module (SCM) for a specific amount of time.
    Possible Causes
    CAN C BUS OPEN OR SHORTED CONDITION
    NO POWER TO STEERING CONTROL MODULE (SCM) — MODULE UNPLUGGED OR OPEN FUSE
    POWERTRAIN CONTROL MODULE (PCM)
    Guess I better get her to the dealer.
    Magnesium Pearlcoat
