Hey it took about 20 minutes to change the bulbs. All I did was remove the four screws and plastic push/pull fastner reached up inside and turned it CC and it has enough wire length to come completely outside below bumper for bub change out. I did wash hands and give new bulbs once over with A swipes before reinstalling.
Also I have a 3/8th inch hole drilled through bottom of bumper to stick a T20 Torx though to adjust the lights when needed, the hole is not visiable unless you stick your head under the bumper. I first thought about using a hole saw for my drill to cut a 3" hole in the black plastic that connects to bumper but decided against it because it was too much work in a 96 degree garage. It would have required jacking up car, and I was not sure if I could get my big hand through anyway. My luck would be I would get my hand stuck trying and be laying there all day till the wife got home in the 96* heat... stroked out.
Lead, follow, or get the hell out of the way.
'05 MB E320 CDI Alpine White, mine 145 MPH+ & 37 MPG
'91 MB 300D 2.5L Turbo, wife's 117 MPH & 33 MPG
