Fog Lamp Loose Wire
apparently, i have a loose plug somewhere. the fog's wont come on unless i hit a largish bump, and then they stay on fine, and will come on if the car is stopped and restarted in a short time. the next day, the fogs wont come on until i hit another bump. this is after one year of trouble-free operation.
i had the dealer add the fog kit, where are connectors located that might be playing a part in this problem?
nobody knows where the add-on mopar fog lamp harness connects to the cars wiring?
well there are two that the lamps plug into.. and there is one up near the front fuse box and then there is a wire that plugs into the front fuse box from underneath... there is also a ground on the passenger fender.
Check em all
Russ
- Falken 20" Explict Black rim,Falken 255 45 20 tires,8"LCD monitor headrests,12" LCD monitor in custom tri fold in back,custom made CIA,Infinity engine cover w/custom paint,custom painted centre bezel & console,custom lit cup holders, LED interior lighting & grill lites,HID's,300w sub amp w/custom enclosures,custom hand-made mesh grill
will do, and thanks. since both lights are on or off together, im thinking ground. is there an actual relay?
yes.... Press all the relays and all the fuses back down in the front fuse panel.
Check your user manual for the location of the fog lap relay (i'm not sure off hand which it is)
Russ
next time they don't illuminate, jump the relay. you can locate the relay by checking out this post. to bypass relay, jump pin 30 to pin 87 in relay socket.
Izzy pics
- You may not post replies
- You may not edit your posts
Forum Rules
