Results 1 to 15 of 16
    mattready's Avatar
    mattready is offline LX Newbie
    ESP mod vs. Fuse 17 .... ?
    what is the difference between pulling #17 and doing the ESP disable mod?
    RTjunkie's version of the ESP Mod writeup.
    does 17 control this system and more?
    reason i ask, i want to add a remote switch for "fun time". i want to minimize the amount of switches, so which one is best?
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Pulling 17 will disable your ABS system. And it really lights up your dash too. You would be miles ahead to complete the ESP disable mod and keep your ABS functioning.
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    And if you have an 06' the fuse 17 won't work anyway.
    BFNY PERFORMANCE
    RIP My Friend
    mattready's Avatar
    so CAM...... will i log any codes or CEL once i go back to stock with the ESP switch? thanks!
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by mattready View Post
    Not that I remember. I have yet to get a CEL except with the $.25 fan mod. If you do and you have the super chips tuner, you can clear them. If you through any codes, pull fuse for a couple minutes and then will reset.
    JonzMgnm's Avatar
    Jan 2006
    Commack, New York
    Quote Originally Posted by Cam View Post
    Not that I remember. I have yet to get a CEL except with the $.25 fan mod. If you do and you have the super chips tuner, you can clear them. If you through any codes, pull fuse 11 for a couple minutes and then will reset.
    Edit for fuse number.
    John Y
    Cam's Avatar
    Cam
    Oct 2005
    Riverside, Ca
    Quote Originally Posted by JonzMgnm View Post
    Thanks, but I like to keep'em guessing.
    Sorry dude, does it count that I was thinking it and not typing it.
    ZMagnum's Avatar
    Tucson, AZ
    Pulling fuse 17 on an '05 works great. There are no codes after you put the fuse back in again.
    fnkychkn's Avatar
    greasy cardboard box
    Quote Originally Posted by ZMagnum View Post
    none that you can see.
    ZMagnum's Avatar
    Tucson, AZ
    Hidden codes? Then pull fuse 11?
    MadCharger's Avatar
    Apr 2006
    Huntersville, NC
    I get hidden codes every time I run the ESP delete mod also. They don't show up as a CEL, but the SC does find it in the DTC's.....
    440 Stroker Short Block 4sale!! (tentatively sold)
    2010 MSHS Stroker N/A Champion!
    ZMagnum's Avatar
    Tucson, AZ
    Yeah, you just reminded me. My OBD2 software will reset DTC's too.
    fnkychkn's Avatar
    they are not "hidden". your scanner may not pick them up. pulling fuse 11 only erases DTCs in the PCM.
    NautcaSprt6's Avatar
    NautcaSprt6 is offline Wish you the best BigBob
    Aug 2005
    Brooklyn NY
    Well that is late 06's.
    I have an early 06 and when I pulled fuse 17, WOW, what a rush, but I think Ill leave it in cause smokin my tire days are well behind me. (Well with my 20" rims, wait til winter tires go on my stock rims)
    Im a practical joker, so dont take anything seriously. GOT IT. GOOD.
    Big Thanks to: | www.BilletTechnology.com | www.TVandNav2Go.com | www.VIP300C.com
    ZMagnum's Avatar
    Tucson, AZ
    Interesting. I guess a battery disconnect then? It doesn't really matter that much. It's not like anything went wrong and I'm taking it to the dealership for something. I'm outside of my B to B warranty anyway.
