Results 1 to 14 of 14
Thread: Engine light?
    Blkmagnum is offline LX Newbie
    Engine light?
    I have an 05 Magnum RT AWD that has had a constant engine light issue for the past year or so. I have had it to the dealer at least 7 or 8 times and it continues to come on. I have had the O2 sensors, O2 harness, and one other thing replaced but still no luck. The only mods I have are an intake and I cut the suitcase out and replaced it w/ flowmasters. Any thoughts?
    done's Avatar
    Old Hickory, TN
    Quote Originally Posted by Blkmagnum View Post
    You really need to tell us what the trouble codes are for us to be of help.
    I will go through my records and let you know.
    stitchmonkey's Avatar
    stitchmonkey is offline What's up Doc? Who's drivin this thing?
    Feb 2007
    It rubs the lotion on it's skin, or else it gets the hose again!
    what comes up with the key dance? or on your programmer if you have one? or just get an OBDII code reader from your local auto parts.
    I have it into the dealer again. They called and told me they can't figure out the problem. They have contacted Dodge and they are currently calling around the country to see if anyone else has had the same issues and what the fix is. Apparently the O2 sensors are "lazy." I am actually considering a Lemon Law claim. This has been a continuous issue and it is getting old.
    One thing that keeps popping up in my head is the intake. When we pulled the sensor the goes into the intake off my brother broke the piece of plastic that locks the sensor in place. He added a bit of superglue on it and put it onto the intake. The problem didn't start after that but could this be the culprit?
    Forgive my non-technical jargon I am mechanically retarded.
    LtlDad's Avatar
    LtlDad is offline LX Padiwan
    Nov 2004
    OC, CA
    Turn the key to 'ACC' then to 'ON' position and repeat 3x leaving the key in the 'On' position after the 3rd time. In the center of your dash (where the mileage is), a code should appear and eventually the word '-done' will appear. List the code(s) and someone should be able to help.
    2005 Mineral Gray SXT
    HAS SOME STUFF...
    Thanks for the advice guys I'm still waiting to hear from the dealer.
    Mar 2008
    That superglue may be setting off a code within the sensor. For sure, the first thing I'd do is replace the sensor.
    PPP stage 3 heads, Howards cam 219/227 .600/.575 112 +4, ported 6.1 intake, MMPG 85mm throttle body, MSD "Blaster" coils, JBA headers & mids, Corsa exhaust, Paramount "Dominator" torque converter & stage 2 valve body, BC Racing coilovers, Eibach sways, BWoody links, Razorsedge brace, 226mm Getrag 3.91 LSD, Wilwood "plus 2" big brake kit by TCE
    Well I finally got the wagon back. Turned out the CPU was "lazy" (their words not mine) so they replaced it. Things seem to be working better now.
    Mar 2008
    Glad to hear things are better.
    mr.niftie's Avatar
    mr.niftie is offline LX Love Machine
    Oct 2004
    Oakville, Ontario, Canada
    Hmmm, I also have an '05 Magnum RT AWD which set off O2 related codes when I first got it.
    I'm not buying the lazy sensor theory. That's just one of the reasons we have 4 O2 sensors (the other being ongoing trim adjustments and cat performance monitoring).
    The original connectors were of a poor design and if they did not have silicone grease smeared inside, they would allow water ingress. Mine were so bad that water actuall ran out of the harness when the sensors were popped off.
    Blew it out with an air gun, added the grease, and no more problems!!!
    2002 SeaDoo GTX RFI 800 SDI
    2004 SkiDoo 600 H.O. SDI
    2005 Magnum RT AWD
    2008 Kawasaki Ninja - SOLD
    2009 Toyota Camry Hybrid
    2011 HONDA CBR RA
    "They even have the Internet for computers now."
    Homer Simpson
    Why do I get the feeling more infractions are coming?
    Quote Originally Posted by mr.niftie View Post
    The dealer had already replaced all the O2 sensors and harnesses and the problem continued. I love this car but I am a bit nervous about how many poorly designed components there seem to be on these cars.
    MikeEast's Avatar
    Ducktown, Georgia
    I'm not sure I'd go with 'poorly designed', remember - these things are all designed and built by 'man', and as such, will fail at some point.
    The sheer number of folks registered here who either have or want or have had an LX variant combined with the small number of real problems that have shown up tells me that this is a quality product.
    It's a bummer that you have had a negative experience with yours, and hopefully, after throwing enough parts at it, your issues will go away. You don't usually see O2 stuff until AFTER the long tube headers go on..
    One example I have - how many SCCM (Steering Column Control Module) failures have we seen? Couple-3-4? I had one exhibit some odd symptoms taking my entire steering column offline, but having been working in the computer biz like since it started, I realized that sh!t happens, and that one happened to me.
    Poorly designed? I'm not of that opinion, I think they did damn good on the LX..
    Mike
    mr.niftie's Avatar
    Oct 2004
    If they didn't pack the connectors with silicone grease when they installed the new harness, the problem may appear.
    2005 Magnum RT AWD
    2011 HONDA CBR RA
    Homer Simpson
