Results 1 to 6 of 6
Thread: Diagnostic Mode
    mc57_98's Avatar
    mc57_98 is offline Silver Streak
    Nov 2005
    Austin, TX
    Question Diagnostic Mode
    Went into diagnostic mode, this was one display that came up.
    Last Chime req
    airbag
    VMM 319
    Can anyone tell me what it means, should I be concerned with it. Talked with a mechanic at a 5 star dealership that works on Magnums and he didn't even know that you could put it into the diagnostic mode...I wasn't impressed with his answer. Any help would be highly appreciated!!
    Thanks Mark
    RandomAccess's Avatar
    Monroe,NY
    This should be helpful...
    EVIC Diagnostic Data
    Nothing to worry about... Just indicates that the last alert to extinguish was the airbag light... and that you have version 319 of the VMM.
    Anything serious would throw a CEL.
    12.571 @ 106.71
    cadzilla74's Avatar
    cadzilla74 is offline Does this smell like chloroform to you?
    Jun 2005
    FTW TX
    RandomAccess is correct, just to ease yer mind. As the car cycles through it's systems check at ignition startup it usually ends with the airbag check (at least it does on mine) and the message you are seeing indicates that was the last system checked. It is not an error code or failure.
    mc57_98's Avatar
    Nov 2005
    Austin, TX
    Thanks for the quick replies RandomAccess and cadzilla74!!
    The reason i was kinda concerned was that in the last 3 months while driving and with someone in the passenger seat the airbag light has came on,and stayed on. I pulled over and turned off the car and started it again and it was out. Just thought that this indication had something to do with it. Thanks again!!
    MagnumFreak's Avatar
    MagnumFreak is offline Chasing Dreams
    Jun 2004
    Evans, GA
    If the car detects someone sitting in the passenger seat that is too light for air bag use it will disable it. That is normal. If it stays on when there is no one in the seat or when a regular sized adult is sitting there, then you have a problem.
    2005 Dodge Magnum R/T
    -Martin Luther King, Jr.
    cadzilla74's Avatar
    Jun 2005
    FTW TX
    If you are getting an airbag light with someone in the seat you are due for a trip to the dealer. Unless the weight of the person or object is less than 110 lbs. If you put say, a laptop or a small person in the passenger seat the light will come on because the car automatically disables the passenger side airbag for the safety of the under weight passenger. If the passenger is 110 lbs or more and you get the light you need to take the car in. There are 4 sensors in the seat, the dealer will put a 110lb weight on the seat and recalibrate the sensors or replace any that do not work properly. I had one replaced under warranty. Do not ignore this problem. It will not go away on it's own.
