Results 1 to 15 of 17
    HoonLo's Avatar
    HoonLo is offline LX NINJA
    The netherworld
    Diablo and traction control?
    So once and for all........with a diablo can you completly dissable traction control or do I need the no esp mod!!
    Much you have to learn....Teach you I will!
    12.93 @ 106 so far....
    You may not be interested in HoonLo but HoonLo is interested in you!
    daveleck's Avatar
    daveleck is offline 2006 Magnum R/T
    Kansas City
    I have found that my noESP mod now goes unused, as the Diablo tune exerts very little control over wheelspin. I don't know if Diablo has totally killed traction control and ESP, but it is certainly much slower to engage. My Magnum will barely break a tire loose with the factory tune, but with the Diablo tune, it is a handful on anything but bone dry asphalt.
    2006 Dodge Magnum R/T
    Vortech V-3 Supercharger @ 8psi| JBA headers/midpipes/cat-back | Hotchkis sways | CMR tune by AJ | 422rwhp/448rwtq
    Token's Avatar
    Token is online now First AWD LX in the 12's N/A
    Center of the LX Universe
    You can disable traction control completely, but remember that at the same time you are also disabling ABS.
    12.645@108.18
    Hemi Mag's Avatar
    Hemi Mag is offline Baba Booey
    Nov 2006
    Mississauga
    As Dave posted, with reduced TM the ESP barely works, and the car is a little hairy to drive in the rain unless you drive like a little old lady.
    AC
    http://www.lxforums.com/board/signaturepics/sigpic12069_2.gif
    'When I was arrested I was dressed in black'
    _____________________________________
    Mods: Predator 93 CAI, Air Hammer, Eagle Mani, Stainless Works Long Tubes, JBA Catback, SRT8 suspension, Mopar Sways, REM Strut tower bar and Bumpsteer, Dual weave Grill, Daytona Chin and 20s, CSRT8 Diffuser, Kicker Sub, 6000K & 3500K HIDs, shaved letters, Old skool R/Ts, Hood Struts, 300C Handles & lower moldings, Two toned tails, BT Oil Catch and other goodies, Husky Liners, and Sirius Stilleto.
    13.5@105
    07RTLOVER's Avatar
    07RTLOVER is offline LX Padiwan
    Nov 2007
    Issaquah Washington
    While the subject of traction control is being discussed, I was surprised to find out at the meet and greet "Northwest Gang" at the XXX on Sunday that nobody that I talked to had known about the turn ignition key method of disabling the traction control for our 5.7's.
    It works great! I always felt a little cheated not being able to really disable like our big brothers, BUT WE CAN.... At between 15 to 25 miles an hour simply turn the ignition key to the right as though you were starting up, hold for a few seconds, don',t worry no starter ingagement, and now the chime and mister squiggly and ABS light comes on. And now what I believe is 100% of the bliss that I know I enjoy when my baby gives ME full and total contol of her. Wow kinda kinky.... lol. Well If ya didn't already know ENJOY.
    HoonLo's Avatar
    The netherworld
    Never heard of the turn key thing....u have tried this?? Does it come back to normal after turning the car off?
    07RTLOVER's Avatar
    Nov 2007
    Issaquah Washington
    Sorry the thrill is for that ride only, when you shut her down it's back to normal. The answer is yes I have tried it many times. Try it but hey........let's be carefull out there.
    NVRDUN's Avatar
    NVRDUN is offline LX Guru
    Las Vegas
    With the Diablo, when you disable ESP, do you then have to turn it back on with the Predator? Or can you turn the car off then back on to reset the ESP??
    07RTLOVER's Avatar
    Nov 2007
    Issaquah Washington
    No, if you change the setting via Diablo, then you must go back via Diablo.
    InferAl's Avatar
    InferAl is offline "R.I.P. Lou1355 "The Hellbitch lives On"
    Nov 2006
    NE Ohio
    With my last B&G tune Torque Management and ESP were totaly eliminated all the time. I wasn't crazy about it being totaly off all the time.
    But it is unbelevable when it is totaly off
    Video
    Magmus's Avatar
    Magmus is offline LX Padiwan
    Jul 2007
    Quote Originally Posted by 07RTLOVER View Post
    ......But it is done through quick adjust so you don't need to reload the tune. Not a big deal, only takes a minute.
    2005 Magnum RT
    BES/HHP stage 1 cam
    BES/HHP PP Heads Milled .030
    AFE Stage 2 CAI
    JBA Shorty Headers
    JBA Catted Midpipes
    Flowmaster 50 mufflers
    Stock Resonators
    HHP CMR Predator Tune
    180F Thermostat
    07RTLOVER's Avatar
    Nov 2007
    Issaquah Washington
    Hey Gang, on the way home from work I realized there was something I forgot to mention. The key turn method only works on April 06 builds and later, real bummer for a ton of you guys sorry. And now that I think of it I believe I got the scoop on the Charger Forum. So will one of you 5.7 Maggies and 300's later 06 thru 08 go give it a try then throw me a bone on a thread that you start. You will be a HERO!!!!!!!!
    chryslerking's Avatar
    chryslerking is offline Stock Eliminator
    Dec 2005
    Langley, B.C. Canada
    Quote Originally Posted by HoonLo View Post
    Hey chris how are ya bud? The truth is yes is does completly disable traction control without loosing your ABS ........and you don't have to turn it off on the dash ......my car has no traction in 1st or 2nd with the Diablo
    mnunes's Avatar
    mnunes is offline That guy
    Jun 2005
    Fountain Valley, CA
    Quote Originally Posted by NVRDUN View Post
    Actually, you don't need the Predator to re-enable ESP. Just press the ESP OFF button on your dash before you turn off your ignition. The next time you start the car ESP will be functional again. If you want to fully disable ESP again you DO need the Predator.
    How do I.... EVERYTHING!
    SoCalLX - Where Southern California Car Culture Meets Modern Mopar Muscle
    HoonLo's Avatar
    The netherworld
    sWEET INFO THX!!
