Results 1 to 15 of 19
Thread: Battery Life
    garabed53's Avatar
    garabed53 is offline LX Newbie
    Aug 2005
    Altamonte Springs, Florida
    Battery Life
    I have had my Maggie for almost 6 years now and I'm amazed my battery is still going strong. I mentioned this to a dealer mechanic recently and he said that the battery being in the rear compartment is keeping it away from the heat of the engine, making it last longer!! Another good reason to own a Magnum, taught I'd pass that tidbit around.
    Charlie in Orlando
    2K6 MAGNUM SXT
    Silver Steel Metallic Coat - 18" R/T wheels
    moaugust88's Avatar
    moaugust88 is online now I'm up all night to get lucky!
    Nov 2009
    Chicago
    I think my stock one would've lasted a couple of years more, but with slower starts and the lights dimming it was best to replace it with Wal-Mart brand battery. Also I put a newer thicker ground wire to the car and it starts pretty quick.
    2006 SRT 300C R2C
    CAI and a ton of mods...
    Quote Originally Posted by fatchance
    You take a four-door sedan and make it a rocket ship.
    critterCQB's Avatar
    critterCQB is offline ǝıʞunɾ ɟxl - ɹǝƃuɐp qoɔɐɾ
    Atlantic Beach, Fl
    When it DOES come time to replace it, hit walmart. No sense in wasting your money. There's a thread on here a LOT of us have chimed in on.
    Sgt Williams USMC/0311/8152/8154 OIF'05
    89grand's Avatar
    89grand is offline LX Guru
    Phoenix, AZ
    Mine took a crap about 1 year ago, so mine lasted maybe 4 years.
    2006 Dodge Magnum R/T - SC Flashpaq, Volant exhaust, 22x9 Challenger SRT8 wheels, 265/35/22, 14.1@98MPH
    2000 Jeep Wrangler
    1966 Dodge Monaco 500
    critterCQB's Avatar
    Atlantic Beach, Fl
    Here it is. Please remember this thread. Get the 94(stock replacement), not the 49 (bigger one). I picked up a 49 and it barely lasted 2 years. As it turns out a bigger battery makes more work for your alternator! Who knew!?
    $75 Vented Battery Confirmed
    garabed53's Avatar
    Aug 2005
    Thanks for the tip on the battery. A good friend of mine works at WalMart, so I can get it with a 10% discount too!!
    IES99's Avatar
    IES99 is offline IES99
    Charleston, South Carolina
    5 years on my OEM. Wally World battery now.
    It isn't easy being GREEN
    crazy_luck's Avatar
    crazy_luck is offline I know where Hoffa is...
    Belle Plaine, MN
    Mine will be 6 years this August (build date of car) - I keep my 12v booster pack in the car just in case, especially since this spring the battery was dead after sitting all winter (even with a trickle charger on it for most of the winter (GFI outlet tripped and I didn't know it) and an occasional start-up and moving it from where it sat).
    89grand's Avatar
    Phoenix, AZ
    Quote Originally Posted by critterCQB View Post
    I can't really see any reason that would be the case, that the alternator works harder. I have a 49DL, and it's not rated much different than the stock one. I believe it's rated at 850 CCA, and 1000 CA. The alternator just has to maintain 12.5V give or take a little. It shouldn't matter much...but I guess I'll find out if mine takes a dump prematurely.
    critterCQB's Avatar
    Atlantic Beach, Fl
    Quote Originally Posted by 89grand View Post
    Well, mine did. In the non-punishing state of Florida. I think the coldest that thing EVER got was like 59 deg F. 25 months on an 850 cca battery? C'mon now. I ran the gauntlet of gurus, and they all collectively said the same thing. If you're not pushing subs/amp/anything else, stick with stock application. A bigger battery is not going to make you go faster or necessarily last longer.
    critterCQB's Avatar
    Atlantic Beach, Fl
    Quote Originally Posted by garabed53 View Post
    Really...? Get a new good friend. Just kiddin' bud, welcome to the forums!
    89grand's Avatar
    Phoenix, AZ
    I didn't buy it because it was bigger, as it isn't very much. I bought it because it was reasonably priced compared to the exact fit battery.
    Gdragich's Avatar
    Gdragich is offline Keeping it Green with MDS!
    Mar 2009
    Arlington, WA
    Anyone over 5 years on a stock battery (trunk mount or not) is on borrowed time...and it will choose the a very inconvenient time to remind you of that!
    2005 Mineral Gray AWD Hemi Registry # 1154 Comp Cams 260 cam, Blastin' Bobs 9db, Dual Flowmasters, Gibson Shorty Headers, JBA High Flow Cats, Frankentake CAI, Techco Strut Barce, Taylor Shorties, 180 thermo, 85mm TB, Flastech Halos, Predator-tuned by Diablotoona. 2008 Magnum BB R/T Hemi Registry # 1584 PPP Stage 2 Cam, JBA Shorty Headers, JBA High Flow cats, Heartthrob Exhaust, Eagle Intake, 85mm BBK TB, LMI Intake, SMF Strut Brace, lowered, Tuned by Diablotoona
    drag_racer is offline LX Guru
    May 2010
    Dalmeny, Sask.
    It gets down to -40C or sometimes even -50C up here....not gonna trust a cheap walmart battery. Interstate or Optima only for me. We've got an Optima yellow top here that is still going very strong, and I'm sure it's well over 5 years old
    Performance mods: Predator Tuner, Deleted Resonators, Custom Dual CAI, Toyo Proxes 4 245/45/20 tires
    Visual Mods: Door Molding and Rear badges removed, LED Tails, 20"x8.5" American Racing Phantom Rims, Front upper/lower crosshairs deleted
    Best ET:
    60' - 2.08
    1/8 Mile - 8.99 @ 78.55 MPH
    1/4 Mile - 13.97 @ 99.7MPH
    Jul 2008
    Hughesville, MD
    Mine lasted 3yrs on the dot, and as for the Walmart one its now 105.00 atleast in my area
    CAM ONLY RECORD HOLDER 12.34 @108.89 & 1.66 60'
    Email mailed tuned by Brent@dtpracing.comComp268cam,
