Results 1 to 5 of 5
    gotahemi's Avatar
    gotahemi is offline LX Newbie
    Feb 2006
    Rock Island IL
    AWD body rolled cured!
    Found a VERY cheap way to cure the body roll problem in the AWD RT's. I found out by bracing myself differently while cornering it affects the way the car handles. Your left foot has a pad to push on, brace yourself hard on that side. Here's the tricky part, use the small pedal on the right to brace your right foot. Make sure the pedal is between your foot and the floor board. Seems to level the car right up. :grin:
    Sorry had to do it, It does seem to handle better under power but I think that sway bars may be in store for mine. Haven't convinced the wife, or the checkbook, that the kw's are needed.
    LowGo's Avatar
    LowGo is offline Alter ego of MyMaggieMae...
    May 2005
    Gresham OR
    Quote Originally Posted by gotahemi
    I had to read that "right pedal" thing a couple time before I finally got it... floor the gas pedal!!! Just make sure you do it at the right time!
    Inferno Red '05 Magnum RT AWD - Who says the AWD sits too high?!
    German influenced garage queen .................... German engineered daily driver
    hops23's Avatar
    hops23 is offline Motor Fan Club member
    Nov 2005
    Chicago, IL
    I haven't heard of any sway bars available for the AWD. I talked to Hotchkiss and they said they are currently looking into it.
    2005 Inferno Magnum R/T AWD traded
    2007 BSM Charger SRT8 traded
    2008 BSM Jeep GCSRT8: Option Group I and II.
    gn300's Avatar
    gn300 is online now Tipmaster G
    Nov 2004
    Nova Scotia canada # 1313
    I didn't relise there was a problem with sway?
    I thought everyone was happy with the handeling?
    gotahemi's Avatar
    Feb 2006
    Rock Island IL
    gn, I'd call the handling adequate stock not bad but the body roll annoys the hell out of me. I don't think my Ram body rolls as bad, I feel like I'm back in my '79 Regal when cornering the mag hard. hops, please report back on how much your kw v2's lower your car. I'm pretty relectant to lower mine as it has touched the frame under the transfer case a couple times and I don't want that to get worse!
    '05 Inferno Red Magnum RT AWD "gotahemi"-MDS indicator light, Borla 112, underhood light, glovebox light, Mopar hidden hitch, Superchips Tuner
    '09 Nissan Versa - Stock
    '99 Kawasaki ZX-9R Ninja-Ohlins Shock, Akrapovic pipe, Dymag wheels, Wave Rotors, Built 973cc engine
    Former Rides:
    '03 PT Cruiser - Crappy mileage and 4 power steering failures in two years, otherwise very useful car
