Results 1 to 14 of 14
    boggart's Avatar
    Pittsburg, KS
    LX Auto Headlights for the rest of us
    Forum mate ffd318 gave me this tip and I've done it and figured I should pass it along. It may be here somewhere but I can't find it.
    All along, those of us without the dual climate control have been envious of the auto headlight mod.
    Well, we can have the mod. Kind of. If you don't have dual climate control and perform the mod to the switch, you will then have auto on headlights. Your headlights will come on about 5 seconds after you start the car, day or night. It's auto on, not auto dark sensing. That make sense? I use it sometimes, but turn it off sometimes too.
    For me (05' Magnum SXT 08/04 build), all other light functions work as normal. Low beam, High beam, Flash to pass it all works. It just turns the headlights on when I start the car.
    Anyway, hope this helps someone.
    NC-SXT's Avatar
    NC Coast
    Oops! I ment to post this also. Did this a while back and use it all the time. Thanks
    WWW.DodgeMagnumGrille.com
    jy211's Avatar
    jy211 is offline Professional Slacker
    Jan 2005
    Miami, Florida
    xWCDx's Avatar
    xWCDx is offline LX Enthusiast
    Valencia, CA
    its in the knowledge base if im not mistaken? Or is it another mod?
    2007 Toyota FJ Cruiser
    2005 Pontiac GTO M6 GREY - SOLD
    2005 Magnesium RT - SOLD
    NC-SXT's Avatar
    NC Coast
    FREE Auto-Headlights (no parts needed)
    Follow instructions
    I didnt remove the switch. Just was real careful with the dremel.
    Scarbs's Avatar
    Scarbs is offline BAD MONKEY
    Jan 2005
    Waukegan IL
    I want to do this mod to the wife's Maggie but i want the sensor for night settng anyone got an idea if this could be added.
    Eric Scarbs/ Black Cherri
    Bad Monkey
    boggart's Avatar
    Pittsburg, KS
    I think anything "can" be done. But you have to change out wiring harnesses, buy the sensors, get the computer upgraded. It's really not worth it to me and I have not heard of anyone who has done it.
    Scarbs's Avatar
    Jan 2005
    Waukegan IL
    see ground breaking. I wonder if the plugs are there and you could just plug a light sensor into it.
    Bad Monkey
    Bo's Avatar
    Bo
    Bo is offline Because Unicorn
    Mar 2004
    Austin, TX
    Quote Originally Posted by scarbrs
    Yes and no......
    You cannot just install the sun sensor..... it actually is wired into the ATC climate control panel. The ATC controller is on the CAN BUS, which is what controls the headlights.
    Now, if you want to upgrade the whole climate control system, I am 100% confident you can add the lights..... I have all of the parts in the garage to do the conversion from manual to auto A/C..... I just need to find the time and motivation to remove the dash from my SRT8 to complete the project!
    --Bo
    boggart's Avatar
    Pittsburg, KS
    Any estimate on the price of those parts? Does your parts stash include the light sensor?
    Scarbs's Avatar
    Jan 2005
    Waukegan IL
    see there Magnum. some one is doing it sort of.
    GO BO GO. You can do it You can do it.
    Bad Monkey
    boggart's Avatar
    Pittsburg, KS
    I hope he's successful. I've dreamed of doing the same thing. I'd like to have the dual zone climate control as well.
    But for now, we've got the partial headlight mod.
    flhthemi's Avatar
    flhthemi is offline Steve
    Jan 2005
    Statesville, NC
    Quote Originally Posted by MagnumSXT
    Very cheap, if you can find a Magnum in the bone yard....
    Stock SRT
    Bo's Avatar
    Bo
    Mar 2004
    Austin, TX
    I have been working on this project for a while. I think I have all of the parts that I will need, with the exception of the complete wiring harness for the dash. It is expensive, and I really see no need to make the purchase of that part, as it is easy enough to hard wire the ATC controller.
    As for the other parts, they are not too bad...... I had the ATC in my RT, and the SRT does not have it..... It is one of those things you think you can live without until you have already had it......
    As for this info, I can't be 100% sure it is accurate, as I have not done the actual conversion yet. When I get the project done, I will post all of the details..... but here is the list of parts I have so far. To do the swap, you will have to completely remove the entire dash from the vehicle. The steering column is attached to the dash, and must be removed as well.
    Prices are from www.makeitmopar.com
    ATC controller 55111030AC 108.75
    Blend air door housing 5137700AB 129.00
    Power blower motor module 5061587AA 27.64
    Sun sensor 4596496AA 19.01
    A/C harness 5061097AA 30.26
    Hopefully I will find the time to complete this project right after the holidays and CES..... My free time lately has been spent playing with other things on the SRT8.....:smile:
    --Bo
