Results 1 to 15 of 22
    COOKZ32's Avatar
    COOKZ32 is offline AK RT C-LEG DAVAF
    Feb 2006
    Minnesota, we need longer ski runs
    Auto Headlights On At Dusk
    I know this has been discussed, but I cannot find the previous threads. I think it was GoofyTimL that had some posts on this issue.
    06 Magnum RT, the auto headlights come on when I turn the wipers on just fine. They come on at night, not dusk, my eyes arn't what they used to be and I need the lights to come on sooner. I did find a post where our fellow member added a piece of window tint to the sensor on the dash and that worked fine on his car. I tried the "two button lower spoke control simultaneously" and I was able to read something that looked like it was the setting for this feature, but is there a way to adjust the sensitivity of this feature.
    Thanks in advance for any suggestions or ideas.
    07 Super Bee 0991 * SRT8 pedals custom install by F1fan - Rick and Jina SUPERBEE's - Gloss Black Decals and Custom Paint by Maple Plain Auto Body, Leanord - Seq. Turn Signals, Flashing 3rd brake light - Billett Technology Caps - BMC Performance - DMH Cutous - NoEsp&Fan - Hotchkis Sway Bars - Saint Paul Automotive, Scott - Crazy Luck rear deck BEE - Freebird BEE on custom plates
    Phil Hunter is offline LX Padiwan
    Aug 2005
    Temecula
    Hi, I have the same problem. Depending upon which version EVIC you have, you can addjust the sensitivity yourself. My car has version 4.05 which does not have this functionality. I plan to complain about the auto headlights next time I take the car in and ask them to update the EVIC software to a later version so I can set the sensitivity myself. This thread will explain it all. http://www.300cforums.com/forums/gen...ble-codes.html Phil
    quarky42's Avatar
    quarky42 is offline LX Guru
    Jan 2006
    Las Cruces, New Mexico
    I think my evic is up to date, but since I have a Magnum the auto light sensitivity isn't in the evic display. I think there may be an option via starscan that can be turned on to enable auto headlights in the evic... not certain, but I thought I saw that around here somewhere.
    Did the radiator cap mod: SRT8 is here....
    The Hemi says, "VROOOM!" Hemi Registry #00420
    COOKZ32's Avatar
    Feb 2006
    Thanks Phil & Quarky42,
    I do not have the ability to make changes in EVIC display that I can see. I will check what version it is. Do I need a version higher than 4.05?
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    If you have the climate control, which you must have for the Auto Headlight Mod to work, put the evic in diagnostic mode by holding down the Music Note and Compass buttons at the same time for about 10 seconds.... then using the up down scroll buttons on the left side of the steering wheel, scroll till you find a screen that has "Lgt" in it. The number displayed to the left of it is the sensitivity... I think the range is from 150-220. It will have a > ext to it indicating that if you hit the top button on the left side of the steering wheel, >, It will change something. Each time you hit the > button it will change scrolling up to 220, then it will jump down to 150 and start scrolling again. Put the car in the light condition you want them to come on at and adjust till they turn on. Tada!
    Ok, this was from memory and should be substantially correct... I'm driving down the road typing this from my TrailBlazer work car so I can't verify 100%.
    DON'T FLAME Me if it's only close.
    Good luck
    Don
    pigpen's Avatar
    Minnesota
    GOD!! Another reason to have RT I say!
    Super T's Avatar
    Aurora, IL
    Not on my EVIC revision... 3.61 or whatever the originals were. damn.
    Dupie24's Avatar
    Dupie24 is offline Go Dupont Racing!
    Nov 2004
    SoCal
    That feature in the EVIC is not there on ours 05 Mag RT. Must be an 06 option, wish I had it, sounds like a cool feature
    2005 Inferno Red Magnum RT
    Group I and II, sunroof, tow package, nav, sirius, Uconnect, auto headlights, 20" American Racing Torq-Thrust M Wheels, 245/45/R20 Kuhmo Ecsta ASX tires, KW V2 coilover suspension, Hotchkis sway bars, Zoomers Cat Back Exhaust, Aria CAI. LED smoked tail lights. Shaved rear hatch. Pinstriping by 2-Stix. Custom painted palm tree headlights w\halos & painted fog lamps w\halos by AAC.
    Custom Billet Tech "palm tree" pieces
    And lots of little visual mods that make it ours!
    MagnumFreak's Avatar
    MagnumFreak is offline Chasing Dreams
    Jun 2004
    Evans, GA
    yup 06 only. along with cruise inidication in the evic. Not sure what to do for us 05s. I will hook up starscan Tuesday and see if there is some sort of setting under the vehicle prep section.
    2005 Dodge Magnum R/T
    -Martin Luther King, Jr.
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    Sorry guys, I tried!
    Don
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    Don
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    Hmmmm... isnt that interesting? Couldnt do that with the old forum software!
    BUG BUG BUG!!!
    COOKZ32's Avatar
    Feb 2006
    Thanks Everyone! I really do appreciate all the help I receive here from the members, you guys and gals are great!
    I have version 4.04. I will try to adjust the setting on Tuesday and post the results here.
    quarky42's Avatar
    Jan 2006
    I wonder if MagnumFreak will find anything out for us '05s. Is there any EVIC Update available for '05s that might give us this control? (Or can the sensitivity be adjusted by the starscan if you don't have that Lgt sensitivity screen?)
    7thS0N's Avatar
    7thS0N is offline She's done heck darnit!
    Tampa, FL
    Quote Originally Posted by GasGunR
    I'm afraid to ask how you're doing that!
    Performance: AirHammer, Hi-flo cats, Bassani exhaust, Predator tuned, Mopar perf springs, Hotchkis sways, BT catch can, EGR delete
    Interior/Looks: Custom embroidered Katskins, custom embroidered console & cargo covers, tinted tails (Charg-um), Upper and Lower grills (NC-SXT), 'Cuda stripes, 20" Torque Thrust-M's, MoPower Shaker, MoPower Chin spoiler, PAINT!
    Tunes: Pioneer F90BT, JVC Arsenal KS-AR8004D + Kenwood KAC-7204, Infinity Reference setup including 2 10" subs in custom embroidered RobbyHo enclosures
