Results 1 to 15 of 25
    345 RT's Avatar
    345 RT is offline LX Padiwan
    Hollywood, CA
    Anyone Changed The Front Brake Pads Already?
    My Right Front Brake Pad Is Squiking Already ( Do To Roed Kill) And My Tec At Dodge Said I Need To Get Them Replaced, I Can Not Just Buy One Side I Have To Buy Both.
    Does Any One Know Of A Good Aftrermarket Brake Pad For The Hemi, Or Should I Buy The Mopars For $138.00?
    Thanks
    Son
    Northern Rider's Avatar
    Northern Rider is offline Move Over People Are Racing
    May 2005
    Ottawa, On
    Quote Originally Posted by 345 RT
    Thanks
    Son
    I replaced mine at 15,000 miles (road racing wore them out). Rotors were in very good shape. The pads are Mercedes design and are ceramic. Great heat dissapation; good wear factor and no brake dust!!!
    Use the OEM's. Worth every penny. Awesome brakes for a large 4 door vehicle.
    Never give the competition an inch
    Redfox0099's Avatar
    North Charleston, SC
    Is the $138 for the front only?
    345 RT's Avatar
    Hollywood, CA
    Redfoxx0099 Dude,
    Yes It Is For The Set Of Front Pads
    Thanks
    Son
    May 2005
    Ottawa, On
    I saw them somewhere for $119.00.
    345 RT, I forgot to add - you need to replace both sides. Be careful with your car until they are replaced. You don't want to score the rotors.
    shrinkydinx's Avatar
    shrinkydinx is offline LX Padiwan
    Thanks
    Son
    lay off the caps lock......
    Xen's Avatar
    Xen
    Xen is offline It's the 'baby' wagon...
    LA
    My brakes have started squeaking after long drives, but not after short stints.
    indalecsio is offline LX Padiwan
    South Jersey
    My Mag has 20,000 miles and the brake pads must still be good, because I get no squeaks yet.
    tonyxcom is offline LX Padiwan
    Jul 2004
    Bay Area California
    almost 26k and they look only 1/3 worn.
    gn300's Avatar
    gn300 is offline Tipmaster G
    Nov 2004
    Nova Scotia canada # 1313
    Invest in oem. there is a company in canada advertising brake pads desighed to work with your factory parts! Well da if they wern't designed that way they wouldn't fit would they.
    boggart's Avatar
    Pittsburg, KS
    Wow I Never Would Have Expected Brake Pads To Be $120. Sheeshhhh.
    345 RT's Avatar
    Hollywood, CA
    Jamphat Dude,
    I Leave The Caps On. It Is Easy For Me. The Computer Does The Caps When It Wants To. Do Not Have Special Software. Go To The 13 Second Recipe, And You Will Know Why I Type Like This.
    Bt The Way Y'all, What Is Oem?
    Thanks
    Son
    boggart's Avatar
    Pittsburg, KS
    Original Equipment Manufacturer
    MAGNUM8R's Avatar
    MAGNUM8R is offline Yes I am a pirate, 200 years too late
    So. California
    28 K and the pads look as thick as new. My Intrepid R/t's went 85K plus with factory pads, depends on how you drive, I prefer using the pedal on the right, not the left!!
    An over 40 victim of fate.
    '8R'05 Magnum RT Midnight Blue Pearl
    KW V 2 , Hotchkiss Sway Bars, CF Airhammer intake,T Rex Billet Grille, Body color Airtab Vortex Generators, Chromed stock 18's BFG KDW 255/55/18 Tires,Avon splash guards, Gibson Performance Stainless SteelHeaders, GibsonCat back, SC 91 Performance tune.
    Hi Flo Cats
    redinorange's Avatar
    redinorange is offline Curmudgeon
    Nov 2004
    Orange, CA
    Quote Originally Posted by redinorange
    These are the most dust free pads I've ever had on a car. I'll stick with the stock ones when it's time to replace them.
    I've said it before and I'll say it again, these are the most dust free pads I've ever had on a car. I'll stick with the stock ones when it's time to replace them.
    Attitudes are contagious. Mine might kill you.
