Results 1 to 5 of 5
    HBADGE's Avatar
    HBADGE is offline .357
    Winnipeg, MB, CA
    Adjusting/Aiming Headlights
    I KNOW I should have used the SEARCH button but Im desperate and need to find solid info. Can I adjust them w/o pulling out the headlamps? If so... HOW? Im getting annoyed of annoying oncoming traffic. Wanna do them asap!
    Thanks in advance to whoever provides good help!!
    blknblu is offline LX Padiwan
    Apr 2008
    San Jose, CA
    Yes you can! But the only adjustment available is up/down. Look right behind the headlights and you'll see a knob sticking out with a phillips screw in it. Pull your car up to you garage door at night, you'll need a level surface here, and adjust that phillips screw to move your headlights up/down to your hearts desire! When I did this I would make an adjustment and then drive around the neighborhood to see where my headlights aimed. A couple of iterations of this and you should be set!
    06' 300C - Jade Green
    05' Magnum RT - Inferno Red
    79' Camaro Z28 - Sky Blue
    07' Hurricane 34B - The house on wheels!
    HBADGE's Avatar
    Winnipeg, MB, CA
    Muuuuch appreciated man! I'll take a look tomorrow. To adjust them up and down is ALL i need to do. In the meantime, anyone have a pic of this?
    HBADGE's Avatar
    Winnipeg, MB, CA
    All I could find was the adjustment for the high beams. I need my lo beams aimed. HELP!!!
    Posted via LXFMobile
    Hemi RT's Avatar
    Hemi RT is offline ?????
    Jul 2007
    Medicine Hat, Alberta
    You can't adjust one without the other, you're moving the complete assembly on the magnum and not each lite.
    Hemi Registry #00730
