Results 1 to 15 of 16
    DBTDODGE's Avatar
    DBTDODGE is offline BA Wagon!
    Aug 2005
    Surprise, AZ
    Question 6 banger dif in a RT?
    The 3.9:1 ratio in the standard LX would be nice in an RT. Are they the same (just as strong) as the RT dif? Will it bolt in?
    MAGNUM22's Avatar
    MAGNUM22 is offline LX MEMBER
    Surprise Arizona
    Nope. Won't work. R/T ring and pinion is actual smaller. That would make hugh differnce if change the gear ratio 3.90..
    DBTDODGE's Avatar
    Aug 2005
    Surprise, AZ
    Thumbs down
    Should have known it wouldn't be that simple Thank for the reply!
    obiwan is offline Boring @$$ed Durango
    Feb 2004
    Stockton, CA
    Why not swap the carrier, it would easier than doing the gear swap. That was one advantage Ford diffs had, pull the shafts, drop the pumpkin a toss in the replacement.
    Beast is offline Viet Vet
    Baltimore
    Anyone done that yet?
    Old Navy's Avatar
    Old Navy is offline Cranky Old Fart
    Jan 2005
    Here, There and Everywhere but 150 miles from nowhere
    Quote Originally Posted by Beast
    Been done a some in MB's, even old '80's diesel MB's.
    Lead, follow, or get the hell out of the way.
    '05 MB E320 CDI Alpine White, mine 145 MPH+ & 37 MPG
    '91 MB 300D 2.5L Turbo, wife's 117 MPH & 33 MPG
    MAGNUM22's Avatar
    Surprise Arizona
    They are different size differentials Base LX has 198 MM. R/T has 210MM. and none of the parts are interchangable.
    Feb 2004
    Stockton, CA
    I was thinking take the entire 3rd member and mount it in place of the existing diff. Would make sense that the drive line and half shafts have the same mounting points.
    Baltimore
    A pumpkin swap sounds like the best shot. Any top MB mechanics out there that can answer this one.
    digger10t's Avatar
    digger10t is offline LX Newbie
    Nov 2004
    Washington DC
    what type of difference do you think there would be in 0-60 with the 3.90 gears. i love the highway-speed acceleration with the 2.82's, not to mention the mileage, but i want some more low rpm acceleration. thanks
    2009 G8 GT
    6.0L - Rotofab Intake - Superchips Cortex EMS and Trans tune 13.2@107 2800DA
    2005 Magnum RT
    5.7L - 5 speed AutoStick - 18" GY Assurance ComforTread
    Tow Package
    DBTDODGE's Avatar
    Aug 2005
    Surprise, AZ
    My intent was to ask about swapping the whole dif, not just the gears. Digger10, a swap to lower gears would realy wake these cars up on the low end for sure. In therory, top speed would suffer, but more likely, that too would improve if more useable HP and torque is sitting there beyond the stock rev-limiter. One thing for sure, MPG will drop some.
    '05 RT: Magnaflow Exaust, K&N Typhoon, Intrax ARB (rear), Intrax Lowering Springs, custom Boyd Coddington wheels w/Michelin Pilot Sport PS2 255/30 ZR22
    '93 Lightning: Custom cat-back, K&N, Jacobs ignition, Eaton dif
    graymagnum's Avatar
    graymagnum is offline GRAYMAGNUM
    May 2005
    OLYMPIA, WA
    Smile
    Quote Originally Posted by obiwan
    your corect---this would work---but mpg way down--Bob
    graymagnum's Avatar
    May 2005
    OLYMPIA, WA
    Talking
    Quote Originally Posted by digger10t
    can't have it both ways---standard gearing is a comprimise---i use the paddel shift to set the r's where i want---rear end change big $$----supercharger around 6K------------i really think stock 340hp is way too cool, go like hell when you want to or cruse at 23mpg---come back, Bob
    Rev.Hammer's Avatar
    Jun 2004
    Hunstsville, AL.
    I like that idea! However I would find a junked SXT and snag the carrier so that if the gear blows out from the load you still have your old one.
    NOW THEN:
    What about the ECU? I bet it would throw a code because of the engine rev's not matching the other condition parameters.
    CONTRIBUTE TO CANHACK!
    And the dead shall walk
    Feb 2004
    Stockton, CA
    I've been checking the online wrecking yards in Nor-Cal trying to find one. If I can get it I'll be the ginny pig and test it. I should be able to get my dealer to set the ring & pinon in start scan for me.
