Does anybody know the value of the resistor used in the 82177 kit? I have the 82023 kit and need the resistor. My first thought is to use a 4.7K or 10K? Any thoughts?
Mike
Mike
06 Magnum R/T Midnight Blue
I dont know i had the resistor but i didnt go the TPS i went to the apps switch by the gas pedal....I like it there better i wired in a teather cord with a monetary switch so i can activate it when i want to so it has actually 3 safetys...1 arming switch...2 car must be floored so the ZEX box sees the voltage..3 monetary switch must be pressed down so all 3 need to be working or no spray....thats the way i did it...hope this helps....
2006 MSRT-8 ...GONE....
