Results 1 to 15 of 20
    L.S.D. is offline LX Newbie
    Oct 2004
    whats the best tire set up for 22" WHEELS
    what is the best tire size for 22" wheels
    and also the best tire company to go with
    thanks
    Oct 2004
    My wheels are 22"x 9.5" wide
    the tires can be
    265/40/22 -diameter of 30.4 "
    and a width of 10.7"
    285/35/22 diameter of 29.9"
    and a width of 11.3"
    295/30/22 -diameter of 29.1 "
    and a width of 11.5"
    please give me your oppinions
    thanks
    Cucamonga Red RT's Avatar
    Cucamonga Red RT is offline Now Cucamonga Black E350
    Jun 2004
    Rancho Cucamonga, S. California
    Dude,
    I have a 20" wheel with 275/45-20 and a total diameter of 29.7", it took a lot to get that tire to fit. If your tire sizes are as big as mine, they will not fit without modification.
    If they are bigger than mine by even 1/2", I guarantee you that they will not fit withhout extensive modification to the suspension.
    Next problem, my 275 on a 9" rim with 15 offset barely cleared on the inside. With the wider tires and rims you are contemplating you may have all kinds of rub problems, inside, and fenders.
    My suggestion? Don't buy on line! Go to a shop where you can try all these sizes out before buying.
    needasrt4 is offline LX Padiwan
    Jun 2004
    Columbus, GA
    265/35/22 is the only to go
    2006 Charger
    414hp 421tq after Supercharger
    Heads, Cam, Intake waiting to install
    Still to come, NX, ESP Mod, Bigger Headers and Exhaust
    Oct 2004
    Shaun is that waht you have on your ride? how does it work with the bags?
    BTW ill be calling you in a few
    joe
    Jun 2004
    Columbus, GA
    no i have 255/30/22
    2006 Charger
    Jun 2004
    Quote Originally Posted by L.S.D.
    joe
    I guess my response was not worth acknowledging :oops:
    Jun 2004
    Columbus, GA
    we've run the 265/35/22 on as big as a 22x10 and it worked, but you could go with a 285/35/22 in the back. We are currently running a 255/30/22 because of the bag setup on a 22x8.5, after SEMA I think we are going to a 22x9.5 in the rear with a 295/30/22
    2006 Charger
    FOURTEEN is offline LX Newbie
    Jan 2005
    EFLAND - Triangle of North Carolina
    Quote Originally Posted by needasrt4
    I like the http://www.tirerack.com/tires/tires....omCompare1=yes !!!! They fit fine, no rubs or cuts with 22x8.5 wheels!!
    "Expert on nothing, but with logical opinions about everything!!"
    fatchance's Avatar
    fatchance is offline LX Guru
    Jul 2004
    Huntington Beach, CA
    needasrt4
    Is the man.
    I'm running the 265/35/22 Pirelli and it's the
    best all around tire. The ride is good and you have some rubber to the road.
    "Like" our Spring Festival Page www.facebook.com/SpringFestivalLX
    Facebook: John Fortuno
    twitter: @1fatchance
    TO REGISTER CLICK ON THE IMAGE BELOW
    ronneyf is offline LX Padiwan
    Nov 2004
    Plano, TX
    Ditto on the 265/35/22. If you aren't ready to modify the arms up front, that's all you can do on a 9-9.5" rim (with an offset that keeps the tire tucked under the fender. My dealer tried a bunch of combos and that's the biggest that works (based on what was out a few months ago anyway).
    Good luck!
    deeone is offline Member
    Dec 2004
    Puyallup, Washington
    I thought the 255/30/22 would fit under the fenders better than the 265/35/22?
    2005 Black 300C- All options minus nav, U-connect and adjusting pedals.
    22 inch Oasis forged 3-piece wheels
    255/30/22 NT555 Nitto tires
    Eibach lowering springs (1.6)
    20% window tint
    tinted taillight and front side markers
    color matched engine cover
    On Order:
    T-Rex chrome grill
    rear SRT type spoiler
    wood dash kit-factory match real wood
    More mods to come!
    Nov 2004
    Plano, TX
    A smaller tire like that will surely fit better. I had a pretty bad rub (popped the front fender) when I got in a turn/pot hole combo, so you may want to be a little more conservative depending on your driving environment. As with most custom stuff, you just have to watch it. I once owned a truck I slammed so low, I could roll a coke bottle across a level lot.
    ElCid9903's Avatar
    ElCid9903 is offline LX Newbie
    Jan 2005
    Meridian, MS
    Pirelli 265/35/22s works good for my 22x9.5's. I would say near perfect:
    Jan 2005
    [quote="ElCid9903"]Pirelli 265/35/22s works good for my 22x9.5's. I would say near perfect:
    Ditto!! Pirelli builds great tires!!
    What make, model, and where did you buy the wheels?? Yours are the first that I have seen online that I may like better than my Status Messiah 22x9.5!!
    Why did you choose 22x9.5?? I haven't found a Spec Sheet that lists Rim Sizes for the 265/35R22!!
