Page 1 of 4 123 ... LastLast
Results 1 to 15 of 54
    kkd60 is offline LX Newbie
    Dec 2006
    Video of 218 cam, hemishop heads and 6.1 intake
    http://videos.streetfire.net/video/6...ad000b9fd0.htm
    Please feel free to leave comments.
    MomsR/T's Avatar
    MomsR/T is offline Builders of the 500rwhp 426's
    Houston
    always fun to run open headers and close your eyes and pretend to be a Pro-Comp driver............lol
    Looks almost done dude!
    Dec 2006
    no open headers, thats going through the muffler.
    MomsR/T's Avatar
    Houston
    HOLY CRAP............I guess that makes you a Pro-Comp driver then.
    Sounds crazy..............turn downs?
    Dec 2006
    longtube headers, 3" y-pipe with no cat and a single 3" si/so edelbrock sdt muffler dumped.
    Fondy's Avatar
    Fondy is offline YUUUUUUUUUUUUUUUUUUP!
    Feb 2006
    Fond Du Lac, Wi. Member# 5136
    I LIKE IT.
    i comented. it didnt like that I said Pissed off LOL
    :insert sig here
    lafrad's Avatar
    lafrad is offline Zomg.
    Feb 2004
    Muskego, WI
    holy crap thats crazy!
    Hogward's Avatar
    Hogward is offline <==XTRP8R===
    Jun 2006
    D i c k i n s o n, Texas
    Awesome stuff!!
    lafrad's Avatar
    Feb 2004
    Muskego, WI
    Keep us all informed if you can get that thing fully 100% drivable on the MAP system dodge oh-so-lovingly has given us!
    Dec 2006
    that cam has been in there for 20,000 miles with no problem. Idle was at 500-550rpm. Runs really rich at idle and about 11.3 at wot. All I did in the video was change the heads and intake.
    lafrad's Avatar
    Feb 2004
    Muskego, WI
    Really!?!?
    I missed if you get any Misfire codes or such...
    Do you get any computer codes?
    Dec 2006
    rich and misfire. Sometimes multiple cylinder misfire shows up. I will fix the rich issue with the psc1-003 that should be here soon.
    MomsR/T's Avatar
    Houston
    I believe those misfires will cause the CPU to pull timing............
    I think you'll find the larger head with the larger plenum will want to make power further up the RPM band.............further enhanced by the fact you may have a narrow LSA thus a fat overlap.
    That overlap might cause the MAP to see less vacumm thus add fuel...............thus why you may be running a bit fat
    A narrow LSA with less over lap should help that combo out, bring torque back down, lean out the combo and make more power across the entire curve.
    But its only a guess...........
    Dec 2006
    I have a psc1-003 on its way to tune the motor to get rid of the rich issue. I like the wider lsa. With a scanner hooked up, no timing was being pulled. I really only get the misfire when I let it idle in the mornig to heat up inside the cab. If it sits at idle for too long it throws the code. With this cam, I have dynoed with more tq than ay other NA truck that I know of with the exception of one who has alot more mods than me. I had 350+ rwtq with headers and a 218 cam and that was it.
    Dec 2006
    I dont mind loosing a little torque down low as I am getting a 3200 stall in a couple of weeks. Then when the tranny breaks, Im going to a 2500 manual tranny pcm and a 6 speed manual.
