trailer wiring-need definitive answer
ok, every car that i have ever wired for a tailer was either so old, or originally had an engine so small, that there was never any chance that i would get out of splicing wires, drilling holes and such
or was an m998 or m1079 that had everything and just needed a new plug.
i have an R/T that did NOT come with the tow package. i know what i can tow, what i cant, have no plans to put in the heavy duty stuff, and never want to tow anything that would neccessitate installing a brake controller.
i installed the mopar hitch with the 2 inch opening, have a mopar ball mount for the 2k weight, and a 2 inch ball, which i used without issue to tow my new(ish) trailer home today
the tailer is a simple 5x10 tilt, with a 4 prong connector.
i have searched and found a lot of answers to other questions, but no clear answers to the following.
if i have do not have the tow package, will i have to cut wires to splice in the trailer stuff?
if i dont, what is/are the part numbers of everything i will have to get to install this.
i know this seems ridiculous, but the 4 pages of posts i looked at before posting this...well, i could never pair up part numbers with weather the person had a tow package to begin with, or if it was for a 7 pin, and so on.
if someone would be so kind as to answer this, i will make sure and send dmag a how to on whatever is involved after i get it installed.
05 magnum rt
83 300TD with waste veggie kit
92 nighthawk 750.
burn vegetable oil to work, burn rubber on the weekends!
