Page 1 of 5 123 ... LastLast
Results 1 to 15 of 62
    Hetrain is offline LX Newbie
    Jun 2004
    Total List Of Problems (Help)
    Lets have everyone put the problems they have INTO one thread, here. This will help people looking to buy, and people who havent got the car yet. If possible, state how it was fixed. Ill start it out
    1. Right Pull
    Vanilla RT is offline LX Newbie
    Jun 2004
    Jacksonville
    2 problems so far.
    1. right pull
    2. right front caliber froze.
    3. windshield fogs up with A/C on
    2005 Magnum RT; Cool Vanilla
    2000 Durango
    1987 Buick Grand National
    Tzar007 is offline LX Padiwan
    Quote Originally Posted by Vanilla RT
    2 problems so far.
    1. right pull
    Are you on recirculate rather than fresh air? That could EXPLAIN why it fogs up.
    Honda Prelude 2001 Owner...
    Test drove a Magnum...
    Changing for a Magnum in Spring 2005 !
    duglas is offline SRT8 Owner
    Jun 2004
    Chesapeake VA
    1. Pull to Right(fixed, but then steering wheel was off center(Fixed))
    2. Airbag light on (fixed Twice)
    3. Horn started blaring on its own, dealer ordered new switch
    4. Transmission kicks out of lock out way to soon, kicks down everytime I touch the gas on the highway.
    5. Idles really rough when I first start it, dealer can not duplicate
    Otherwise it is a great car
    2006 Magnum SRT8 Options 1 and 3, Sunroof
    Zoomers, K & N CAI, Jet Chip Stage 2 180 Therostat
    Rk Sport Hood, Mopar Remote Start
    RX 75 PRO Radar Detector
    $.25 Fan Mod (Cost me $6)
    392.5HP 394 FT LBS!!!!!
    13.02 1/4 Mile
    1972 Dodge Challenger 6.1L SRT8 6 Speed
    1995 Nissan 240SX SE Stock
    2005 Toyota Sequoia
    1997 Jeep Wrangler
    2005 Dodge Magnum R/T Blue 321.9HP 372 Ft LBS-SOLD
    1965 Corvette Convertible. 327/365HP red/black SOLD
    Blanchman is offline LX Padiwan
    Ventura, CA
    Problems encountered so far:
    1)
    Wow, no problems. Is this really a Chrysler automobile ??
    DucatiBoy is offline LX Padiwan
    Jun 2004
    I had:
    1. Sticky right rear door hinge (needed new hinge)
    2. Moonroof/sunfoof not aligned properly (fixed but dealer caused #3)
    3. Sunshade was stuck open and wouldn't close
    4. cracked steering wheel silver inlays
    5. radio sometimes (when the car is turned on) changes to FM and has no sound, volume won't go up, only down, still no sound. Need to power off and power on radio to reset.
    6 surging at speed, feels like the mds cutting in and out. There is a TSB to fix this FROM what I was told.
    All small nit picky things, but I still love the car.
    KintlaLake's Avatar
    KintlaLake is offline riding. riding. riding.
    Jun 2004
    Columbus, Ohio
    1. Right pull (slight, listed because I'll have dealer CHECK it)
    2. Buzz in rear speaker mounts
    3. Sunshade seal detached at RH end
    4. Wipers operate only on high speed (happened once, hasn't since)
    5. LH rear window inoperative with either switch (intermittent)
    6. Surface cracks in steering-wheel trim
    7. EVIC displays incorrect outside temp, apparently affects climate control (happened once, hasn't since)
    Mischief is offline Yeah, it's got a Hemi...
    Jun 2004
    Cabot, AR
    Car pulls ever so slightly to the right
    Right rear speaker buzz even when the radio is turned off
    left rear window operates intermittently (but works when I'm near the dealership)
    There is nothing else that I can think of right off the top of my head.
    I love this car!!
    2005 Inferno Red Dodge Magnum R/T
    Sort-of Stock
    C4me is offline LX Padiwan
    May 2004
    Ohio
    2 problems so far.
    1. right pull
    TWO problems??
    1.
    2.
    3.
    MauiHemi is offline Vrooooooommmmmmmm
    Jun 2004
    Pukalani
    Mostly minor but here is my list
    1) Power adjustable brake pedal does not adjust
    2) Auto wipers don't always activate with rain but do activate every time I signal a turn
    3) Damn Oil Filter was screwed on way to tight
    4) Scratch in dash bezel buy analog clock
    5) Uconnect indicates 0 for signal level and battery level
    I'm not talking incoherently, you just haven't had enough caffeine!
    markyneutron's Avatar
    markyneutron is offline Snow Drivin Maniac
    Brampton Assembly
    1. length of time with no VIN: 63 days (9 weeks as of Oct 11 2004)
    I like to pass that's why I love this car
    2005 Magnum RT
    Tommy T.'s Avatar
    Tommy T. is offline LX Padiwan
    May 2004
    South Texas
    Known issues so far:
    -- Replaced driver's window switch assembly since it wouldn't control rear driver's side window
    -- Rear seat driver's side seat belt buckle installed backwards. (The release is on the underside of the buckle when buckled, instead of on top) It's not twisted either, already checked.
    -- Parking brake: Have to really push in to get it to work. Tested by parking on incline with car in neutral. Rolled back unless pedal was REALLY depressed.
    -- Headliner is a little jagged where it meets the windshield.
    -- Right pull (slight)
    -- Fit between bumper and hood, slightly larger gap on the right side
    -- Insufficient paint on front bumper, if you look close (as in get on your knees and look in the hard to see areas around the grille) you can see that there are sections where you can see the dark plastic underneath.
    -- Slight rattle / flapping noise due to loose / flimsy front wheelwells
    Having said that, I love driving this car. I consider these minor, minor issues that don't detract FROM the overall experience. Plus, most of these are easily taken care of.
    -- Tommy
    My other rides:
    1995 Chevrolet Impala SS . . . 260 HP / 330 lb-ft . . . all stock
    2005 Dodge Ram 1500 SLT . . .Hemi-powered Lone Star Edition
    P-3 Orion . . . . . . . . . . . . . . 4600 SHP x 4 engines
    Inferno Red RT ordered 7/12/2004 . . . gave up on it for a Cool Vanilla RT.
    SD68XR7 is offline HIGH EXALTED MYSTIC RULER
    L.I, N.Y.
    1. driver side "HEMI" emblem not on straight, dealer ordered but it still bugs the $hit out of
    me.
    2. hood not on straight, larger gap on drivers side.
    3. Tailgate WAY out of alignment, it hits the interior trim when you try to close it,
    all to be fixed when the "HEMI" trim comes in, I noticed all these things in the first two days but I couldn't bring myself to be without the car, so I waited 2 weeks.
    I've been checking closely at the steering wheel inserts and I think the right one may be starting to SHOW the hairline cracks in them. I'll let it go for now but if they get worse...
    LRS1 is offline LX Newbie
    Jul 2004
    Whittier , Ca
    1. Right Pull (Dealer ordered bolt kit)
    2. Radio and interior lights flicker when radio is turned up while ignition is off
    3. Rough Idle and Spark knock (seems very loud)
    On that last one,Anyone else experiencing this ? The Dealer tried to tell me the Magnum RT just made a loud "clicking" noise, and now I see a TSB for this exact problem.(Havent called dealer yet)
    2005 Magnum RT
    2004 Hemi Ram 1500
    Pablovision's Avatar
    Pablovision is offline LX freak
    Toronto, Ontario
    The window buttons bug the crap out of me, I can't see the lights on them in the darkest night unless I hold my head directly over them. I asked about this at the dealer and they said it was supposed to be like that. Aren't the sunroof buttons supposed to light up as well? I only ask this as nothing on the ceiling console worked when I first got it and this seems only logical.
    Hmmm, I can see it now, cruising down the highway and HAVING to hold my head over the switch to see it then WHAM! because it also drifts slightly to the right and my steering wheel is aimed off centre.
    It's the little things but what a car!.
    Paul.
    Y'all know I got me a Magnum, why else would i be here?
