Results 1 to 15 of 16
Thread: Tires
    dchemi's Avatar
    dchemi is offline LX Enthusiast
    Rochester, NY
    Tires
    Has anyone found any tires to REPLACE the OEM tires?
    I think the OEM tires are weak. I have been looking to upgrade to a more high performance tire. All of the tire manufactures web sites like Goodyear, Dunlop, Michelin and any other one I could think, of do NOT have tires in the size that the Magnum needs. Has anyone found a good replacement tire
    Rev.Hammer's Avatar
    Jun 2004
    Hunstsville, AL.
    hooo boy, there is a loaded question! Not to sound priggish, but do a search for tires and wheels because there are actually a fair number of combos that will work.
    And the dead shall walk
    Bob W is offline LX Newbie
    Jun 2004
    Reno, Nevada USA
    2005 Dodge Magnum RT.
    1958 Dodge Coronet 2DHT.
    1957 Chrysler 300C 2DHT.
    1957 Desoto Fireflite 2DHT.
    1957 Chrysler Winsor 2DHT.
    1960 Desoto FireFlite 2DHT.
    1958 Desoto Firedome 2DHT.
    Cucamonga Red RT's Avatar
    Cucamonga Red RT is offline Now Cucamonga Black E350
    Jun 2004
    Rancho Cucamonga, S. California
    Bob,
    why the 245s? Why not something wider?
    What was your reasoning for changing the tire?
    tonyt's Avatar
    tonyt is offline LX Guru
    Suffolk, VA
    Anyone know what the range is for the stock RT rims?
    Tzar007 is offline LX Padiwan
    Quote Originally Posted by Cucamonga Red RT
    Bob,
    Could be because the width of the stock rims does not allow for wider than 245 (what's the width of that stock rim by the way?).
    The other thing is that the only other available size wider than this (and that will NOT screw up your speedo and mileage) is 255/55/18. In this size, you get quite a few models and the margin of error on the speedo will be 1.4% (see tire size calculator here: http://www.miata.net/garage/tirecalc.html), that is reasonable.
    If the stock rim width would allow it, you could theoretically have 265/50/18 or 275/50/18. These sizes are even better since the margin of speedo error is only 0.7%. Unfortunately, no companies (at least on Tirerack) seems to be making these sizes.
    Honda Prelude 2001 Owner...
    Test drove a Magnum...
    Changing for a Magnum in Spring 2005 !
    MySRT's Avatar
    MySRT is offline LX Guru
    May 2004
    Charlotte, NC
    Stock RT rim is 7.5" wide.
    Don
    Live Well, Love Much, Laugh Often
    www.caringbridge.org/visit/donpusso
    Quote Originally Posted by MyRT
    Damn, can't find a proper wheel/tire fitment TABLE on the net, but I don't believe you can go over 255 with a 7.5" wide rim (with a height ratio of 50). It's starting to stretch the limit.
    Funkrider is offline LX Newbie
    May 2004
    Hamilton, Ontario
    Personally I wouldn't use more than a 235 on a 7.5 inch rim.
    Ian
    '82 Mercury Capri SOLD
    '00 Mazda Protege ES
    '03 Ford Crown Victoria P71 5spd conversion
    dchemi's Avatar
    Rochester, NY
    Tires
    Thanks for the replys, but I would like to stick with the stock size.
    Let me restate my question.
    Has anyone found OEM size tires that offer better performance? Such as a higher speed rating or better snow traction.
    MySRT's Avatar
    May 2004
    Charlotte, NC
    The stock Conti tires are the only tires I have been able to find in 225x60x18.
    Don
    Re: Tires
    Quote Originally Posted by dchemi
    Nope. Tirerack.com, which offers 17 different brand of tires, only shows those damn Contis when you do a search for 225/60/18. I also looked for Toyos, one of the few major brand which are not carried by Tirerack, and they don't have that size too.
    The problem is the 60 ratio for the height. You can get all kinds of 18 inches performance tire when you lower to 55 or 50 and increase width. But the stock size is just plain weird: not enough low, not enough wide.
    PropMan is offline LX Padiwan
    May 2004
    Hollywood, CA
    I recently replaced the OEM Continentals on my RT for a couple of reasons--first one being my left front was destroyed due to sidewall damage FROM a road hazard and the second being I just could NOT pay $125 for one of these CRAPPY tires! So I bought FOUR of the 245/55ZR18 BFG tires FROM Tire Rack. WHAT A DIFFERENCE--while they are still 4-season tires they grip MUCH better than the Continentals and are very close in terms of "comfort." Worth every penny of the $400 I spent . . .
    bri
    bri is offline LX Padiwan
    leesburg, va
    Re: Tires
    Quote Originally Posted by Tzar007
    hit the nail on the head there - the overall diameter of the 300/magnum tire is much larger than probably 90% of the production cars out there, but not big enough for larger truck tires.. 28.6" is huge! compare to the stock diameter for a civic - 24.9" or accord - 25.7"..
    gonna be a while before the niche is filled to our liking..
    May 2004
    Hamilton, Ontario
    Quote Originally Posted by Funkrider
    Actually one thing I didn't keep in mind was that we aren't talking about a low profiletire here so its not as much of an issue. 245's Should be a nice addition.
    Ian
