Results 1 to 8 of 8
    Sevenernine's Avatar
    Sevenernine is offline I'm doper than Floyd Landis.
    Jan 2009
    Lawrence, Kansas
    SRT Headers/Mids on R/T?
    I searched, but can't seem to find a comprehensive source of information on this, other than this thread (JBA vs Stock SRT8 header on 5.7?)
    Basically, I wanted to swap out my exhaust for an SRT exhaust if I can find one for cheap enough.
    What are the difficulties/benefits of doing this, and is it worth doing?
    Basically, what all do I need to swap out to do this right?
    Can I just bolt up the headers/mids/and catback from an SRT?
    Making sexy look easy since 1983.
    Stay Subtle
    Quote Originally Posted by CVP33 View Post
    Get a procharger. I only chirp 4th now. The other gears are just a blazing, screaming, tire shredding, smoke filled show of power. But definitely no chirping.
    seanol's Avatar
    seanol is offline Proud member of the Fugowie Tribe
    Jan 2006
    Las Vegas
    Yes.
    The entire system bolts up fine. I have the SRT headers with the flange modified for the egr valve, I ground down the welds in the SRT headers as well.
    Mids and cat back fit the car exactly. I used challenger headers I got off of ebay for $25.00. SRT mids were $150 (thanks Erik!) and my catback was $50 on craigslist.
    Excellent mod, no drone other than MDS and good S.O.P. feel.
    Ask away if you have any other questions.
    As for a parts list you will need:
    6.1 gaskets, 16 6.1 exhaust bolts, 1.25" spacer for dipstick retention and alot of bandaids if you are doing this in your garage on jackstands
    http://lxforums.com/board/showthread.php?t=169028
    http://lxforums.com/board/showthread.php?t=133858
    http://lxforums.com/board/showthread.php?t=159740
    http://lxforums.com/board/showthread.php?t=136033
    http://lxforums.com/board/showthread.php?t=158467
    http://lxforums.com/board/showthread.php?t=155433
    http://lxforums.com/board/showthread.php?t=153202
    http://lxforums.com/board/showthread.php?t=151462
    http://lxforums.com/board/showthread.php?t=146400
    http://lxforums.com/board/showthread.php?t=145094
    http://lxforums.com/board/showthread.php?t=141700
    Let me know if you need anything clarified,
    Sean
    gremlinsteve's Avatar
    gremlinsteve is offline Supporting Vendor
    Apr 2006
    did this on the wifes car a few months ago.
    273/305 stock...
    after the 6.1 shortie, magnaflow high flows cats and the magnaflow 6.1 cat back the car made 285 / 350
    not a bad gain....
    steve
    gremlinsteve, it does a body good!
    FRANK RACING INC.
    specialized cyl. head development for the 5.7 and 6.1 hemis.
    www.thehemisource.com
    mlgreen's Avatar
    mlgreen is offline LX Padiwan
    Milwaukee, WI
    So do you guys get any codes with the full srt exhaust swap?
    mlgreen's Avatar
    Milwaukee, WI
    Quote Originally Posted by mlgreen View Post
    So after reading the links that seanol posted (thanks a lot btw) it seems like there needs to be a notch made for the egr. What about the oxygen sensors? These guys are nazis when it comes to emissions around here, I want to be sure i'll pass. Currently i'm stock except for Borla 125 catback. I already have srt8 headers and midpipes, and i'll probably just buy a 6.1 SLP LM1 exhaust so everything can bolt right up. Will this setup pass emissions with egr notch and o2 sensors?
    Fargo59's Avatar
    Fargo59 is offline building for the better!
    Welland ON
    its made of stock parts, so yes. it has what they want. 4 o2 sensors, 2 cats, and looks "stock". it'll pass.
    seanol's Avatar
    Jan 2006
    Las Vegas
    The only problem I ran into on my car was the driver side rear o2 sensor(might bee the front, I don't remember but you will know it). The wire was a little short. If you undo the harness holder at the head you will gain the needed distance so you don't stretch the wires and risk pulling out the wires from the connectors.
    The notch is on the header flange face so you will never see it and it will pass the required amount of exhaust gas for emissions. You will need to drive around a bit to get into ready state if you disconnect the battery I think. You definitely want the battery disconnected if you do this work.
    I used an SRT catback and I am happy with the sound. Not too loud but has a nice growl when you get on it. You will hear MDS mode but I turned it off.
    No codes in over 2000 miles so far.
    Sean
    mlgreen's Avatar
    Milwaukee, WI
    Cool, thanks for the replies guys. Time find a cheap srt exhaust
