Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    NVRDUN's Avatar
    NVRDUN is offline LX Guru
    Las Vegas
    Royal Purple oil....any good???
    Im about due for an oil change and the shopette here on base just got in a couple cases of Royal Purple 5w-20. Is this stuff any good? Also the last oil change I used Mobil 1 5w-30, is it okay to go from Mobil 1 to Royal Purple?
    da BoMM's Avatar
    da BoMM is offline Conspicuous Combustion . . .
    Spring, TEXAS
    Quote Originally Posted by NVRDUN View Post
    Go for it -- you can't go wrong. Switching brands is no problem, but stick with the 5W20: it's required by the factory for the MDS to work properly.
    6.1L HEMI #622 '07 TorRed MSRT8 1/165= TORRED >< 6.1L HEMI '10 Silver Jeep GC SRT8=4X4JET
    MSRT8 owners http://www.lxforums.com/board/groups/magnum+srt-8+owners/
    MagnumRTMom's Avatar
    MagnumRTMom is offline LX Newbie
    Jun 2006
    NW Louisiana
    I agree! And I used Royal Purple in my RT Magnum. Never had any trouble... and Maggie ALWAYS performed!
    2007 Silver Charger SRT-8
    "Simba"
    Need I Say More???
    Token's Avatar
    Token is offline First AWD LX in the 12's N/A
    Center of the LX Universe
    It's all I've used in mine..... Good Stuff!!
    12.645@108.18
    Reppr's Avatar
    Reppr is offline join date 05/06/2004
    May 2004
    Gig Harbor, Wa
    I have to echo the people above. Good Stuff!!
    Member #197!
    Ah, screw the diet.
    AJ_Gil's Avatar
    AJ_Gil is offline FLXC South Member
    Plantation, FL
    Yup, used Royal Purple the last 3 oil changes and no issues.
    Former 2005 Magnum R/T Owner.
    2007 Moroso Mopar Challenge Champion.
    Gils new (25 mpg) Retro Rod.......
    "The times they are a changin"
    392Stu's Avatar
    392Stu is offline Supporting Vendor
    Nov 2006
    It's popular with the Hemi Truck people also.
    NVRDUN's Avatar
    Las Vegas
    Sweet. Thanks for the help, guess I need to go pick up a case of this stuff!
    hondaman9468's Avatar
    hondaman9468 is online now 05 r/t cool van.
    woodstock, GA
    i love the ****....
    jarrod is offline LX Padiwan
    Feb 2005
    Houston
    It's all I've used in mine..... Great Stuff!!
    JL
    HEMI ONNNNN!!
    05 RT, loaded. AirHammer, JBA Shorties, Hi Flo Cats, Zoomers, SC tuner, 2 JL 10's, JL Amp, Eclipse Amp, Boston Pros in rear, BFG KDW
    more to come
    SublimeTime's Avatar
    SublimeTime is offline "Volatile Villian"
    Quote Originally Posted by AJ_Gil View Post
    I also changed over to Royal Purple. I have a question as I am semi new to the synthetic oil thing but do you forum members still stick to the 3,000 mile oil change rule with synthetic. I am assuming so but please fill me in. Thanks.
    07 Sublime Daytona
    Zex N2O,AFE II CAI,170 t-stat,JBA exhaust,FRI S/S heads,Sparrow cam,Mopar LT's,Ported/Polished Billet Tech 85mm TB, '09 Challenger Getrag LSD.Eagle 09 intake,CTP spacers and driveshaft loop.Custom Edge converter,Paramount Performance flex plate.Install by HEMI31/BFNY Performance.
    Feb 2005
    Houston
    Most synthetic's are good for 6k and over.
    JL
    HEMI ONNNNN!!
    more to come
    Don's magnum's Avatar
    Don's magnum is offline LX Newbie
    Richmond,Va
    Good stuff. Change mine every 5k
    D-RT is offline LX Padiwan
    Northern VA
    Whats so good about RP?
    I've been thinking of switching. I currently use Mobil.
    I'm due for an oil changel like, yesterday........
    If you see me in your rearview, I've already passed you!
    joseph's Avatar
    joseph is offline Banned
    Oct 2004
    Las Vegas, NV
    RP is the only oil that has proven to increase dyno HP, it even made a difference with RP gear lube, plus it's rumored to keep internal part like new.
    I found a good deal on E-bay, $77 for a case of 12qts, bought me 2 cases.
    I also use K&N oil fitlers, they are real good stuff too, don't know if they help performancewise, but I like having the best, they're high flow..., and I love that welded nut at the end of it, makes the job easy when it's time to remove the oil filter (I use it on all my cars, as I have for the past 5 years or so)
