Results 1 to 13 of 13
    speakerboy's Avatar
    speakerboy is offline LX Newbie
    Nov 2004
    Mass.
    Angry Rotors warped and leaking seals!
    My RT has 11k miles on it and I just had to have all 4 rotors replaced. They were warped very badly. The tech said that it looked like they were made from 2 differnt kinds of metal and had some hard spots in them. They also had to replace they inner and outer axle seals, which were leaking. Needless to say I am not very happy. I don't even want to get started about the Conticrap tires which were scalloped as well. Has anyone else had these problems? I know most people hate the tires, but I don't recall seeing any of the other issues.
    Northern Rider's Avatar
    Northern Rider is offline Move Over People Are Racing
    May 2005
    Ottawa, On
    Quote Originally Posted by speakerboy
    Warped rotors are rare on the R/T 300C. May have been mis-diagnosed. Here is some required reading that may save you a lot of money over the years. I run a fleet; it has saved me thousands of $$$$:
    How To Bed In Brakes
    The pads are ceramic and the rotors are a Mercedes design. The hard spots the tech referred to is pad material transfer which would cause "pulsing". Is it possible your service department is generating a little "extra" warranty billing?
    As to axle seals, I cannot comment, other than to say this is the first report I've heard of premature leaking.
    Hope this helps.
    Never give the competition an inch
    Rev.Hammer's Avatar
    Jun 2004
    Hunstsville, AL.
    VERY good article there NR! THANKS!
    And the dead shall walk
    fnkychkn's Avatar
    greasy cardboard box
    Quote Originally Posted by Northern Rider
    i'd bet very few shops do this after pad/rotor replacement because it can be time consuming and nobody wants to pay more than the advertised price for brake service (or any other service, for that matter).
    May 2005
    Ottawa, On
    Quote Originally Posted by fnkychkn
    No they don't. they'd need a country road and an hour of billable time. From their point of view, they just say "warped rotors" - and replace everything.
    magnumdude's Avatar
    magnumdude is offline LX Guru
    Feb 2005
    Near the beach in Cali
    WOW, I have EXACTLY the same problem. Car is in the shop now for leaky rear seals. This is the second time. They ordered new seals and then the mechanic said it should not have leaked again so we want to order another part. Hopefully part will be here on Mon and car back on tues then off to tire shop to test fit new wheels and tires. I will be so p o'ed if I dont have car back on fri for CAI face off! Did they replace rotors on waranty? Thought brakes were not covered?
    I like to pass!!
    fnkychkn's Avatar
    Quote Originally Posted by magnumdude
    WOW, I have EXACTLY the same problem. Car is in the shop now for leaky rear seals. This is the second time. They ordered new seals and then the mechanic said it should not have leaked again so we want to order another part. ?
    make sure they check the axle vent to make sure it is not restricted. this could allow pressure build-up and cause a leak.
    Magne300Csium's Avatar
    Magne300Csium is offline "R" is for race
    Jan 2005
    Eastern Ventura County, CA
    That is an excellent article. Bedding in brakes on a new vehicle should be approached just like the break-in of any other component. I always selectively baby and then hammer every system on a new vehicle and everything seems to last and feel just the way it should.
    The brakes on my 300 have some of the best "feel" of any I have used. The Mustang GT I have feels pretty good too, but that is a hydraulic power assist, not vacuum.
    His: 2006 300C SRT8
    Silver Steel with All Options
    Plus: 275/40/20 Toyo Proxes 4's, Volant CAI, Mopar/Corsa Cat-back Exhaust, Satisfied Brake Pads
    Hers: 2006 Jeep Grand Cherokee SRT8
    Bright Silver, with All Options
    Plus: Satisfied Brake Pads/R1 Drilled/Slotted Rotors
    Theirs: 2001 Mustang GT Convertible
    K&N FIPK, Magnaflows, Steeda Tri-Ax Shifter, Mach 1 & Cobra Trim
    Theirs: 1970 Challenger R/T SE
    Sublime Green, 440 4BBL, 727, power steering & brakes
    Theirs: 1969 Roadrunner Convertible
    Sunfire Yellow, 383 4BBL, 727, power steering & brakes, factory air
    speakerboy's Avatar
    Nov 2004
    Mass.
    After replacing the rotors and an alignment, all was well. Since it was still under warranty, I didn't question much. My dealer seems to be no nonsense, so I don't think they played it up. The new rotors will be broken in properly. Thanks for the info.
    Todd TCE is online now Supporting Vendor
    Nov 2004
    You may want to consider an alternate set of pads which meet your 'spirited driving' if that's how you run the car. The transfer will be greater on a generic street pad pushed to the limit.
    However...the 'performance' pad will do the same thing if you run them hard and pull the car down to a full stop repeatedly in traffic. Stop and go at speed on the freeway can do this too. Remember to creep and or take your foot off the pedal whenever possible and the chance for transfer (those spots) will be far less.
    TCE
    Your one stop...for Wilwood brakes.
    May 2005
    Ottawa, On
    Quote Originally Posted by Todd TCE
    I'd love a set of racing pads for my 300C. Can't find them anywhere.
    Has anyone seen a pad that matches our spec?
    rozkopeeko is offline DA LAWW
    Aug 2005
    Ft. Lauderdale Florida
    does anyone know were i can get larger rotors that i can use with the stock calipers?? i put 22's on my baby and i can feel the diference when i'm breaking it down from 120 lolllol
    magnum lover's Avatar
    magnum lover is online now Crew Chief for #4 SPO
    Jun 2005
    Conklin, NY
    I hear ya! Told the dealer I was feeling a pulsing in the brakes (warped rotors?) and the mechanic took it for a test drive, he agreed with me. Took it in for oil change and replacing the tires (under 11,000) and asked about the rotors. They are going to order them, falls under the 12,000 mile mark, so it's warrenty. Tires were crap about 8,000 miles (worn uneven,feathering), had it aligned (warrenty- toe was off on all 4) now I have new tires, Goodyear's, and it feels great, (compared to what it was).
    05 Magnum Mineral Grey R/T Hemi Reg# 00310
    http://community.webshots.com/user/magnumlover
    albums with headlight/taillight/bezels & interior changes
