Results 1 to 8 of 8
    Little Heat is offline LX Newbie
    Aug 2008
    Delaware
    power supply for predator
    Does anyone know the volt and amps output on the power supply for the predator?
    RobAGD's Avatar
    Reston, Va
    12v 1000mA as I recall will work fine. I use a Radio Shack unit. I dont recall the tip Letter off hand though.
    Look in the HHP vendor area, it was talked about in depth in the Predator Group buy thread.
    -R
    MAGFX is offline Nevermind my mind!
    Dec 2005
    Arizona
    ^^^Yep, what Rob said. I couldn't find mine so I just picked one up today.
    I smile because i have no idea whats going on.
    My friends call me JONN (usually).
    Aug 2008
    Delaware
    Thanks.
    mhigham's Avatar
    mhigham is offline LX Guru
    Feb 2007
    Michigan
    12V, 1 amp is what it comes with. You can prob get away with less amperage just fine. Get a universal one from Radio Shack and it should have the right tip.
    Mike
    06 Magnum R/T Midnight Blue
    Dec 2005
    Arizona
    I did try one with 500mA and it did not light up.
    PowerWagon896's Avatar
    PowerWagon896 is offline Clever Disguise as a Responsible Adult
    May 2006
    Waiting on the gravy train
    -R
    Quote Originally Posted by MAGFX View Post
    I got mine from RadioShack too. 12V 1000ma/1a.
    Be careful W/the tip adaptor as it can be plugged in as reverse polarity.
    There is an index mark, but it is not "keyed". It is also prone to coming loose in the box during storage.
    I covered mine W/shrink tube. That keeps it secued.
    boggart's Avatar
    Pittsburg, KS
    12v 1a is what the Predator materials that came with the unit call for.
