Results 1 to 14 of 14
    usmcdevildog is offline LX Padiwan
    Nov 2007
    Minneapolis, MN
    Possible Leakage '06 Charger RT
    Well I changed the oil for the first time on my car since I've owned it. It's got about 20,000 miles on it. While I was under there I noticed some strange things.
    1: Two power steering lines, one was bone dry and the other looked wet. I checked the level and it did show that fluid needed to be added. So I did.
    2: Looked as if I had an oil leak up near where the oil pan meets the engine. The bolts holding the pan on had oil on them.
    3: Also looked like there was a leak where the transmission bellhousing bolts onto the engine.
    Is this call for alarm? Should I take this in to the shop? If so, what do I tell them? I don't want to waste my money on diagnostic fees and other BS.
    hemiunderglass is offline LX Padiwan
    Nov 2004
    Tampa, Fl
    You're not saying you put 20k miles on your oil, are you? The oil has been changed before, but this is the first time you persoanlly changed it, right? Nah, I don't think there is cause for alarm as long as you keep checking your fluid levels, but if you keep a clean engine you're going to have to fix those leaks!
    Super T's Avatar
    Aurora, IL
    Shouldn't be a leak where the bellhousing meets the engine, there's no fluid in there...
    Hemi Wagon's Avatar
    Hemi Wagon is offline Officer are you sure???
    Jul 2008
    MD
    Could be a bad rear main seal
    That would leak between the motor and trans
    Silver Bullet
    5.7 Hemi Registry #949
    Baltimore Mopar Motor Club #008
    Super T's Avatar
    Aurora, IL
    Quote Originally Posted by Hemi Wagon View Post
    Oh that would be bad news.
    HEMIDON's Avatar
    HEMIDON is offline 426ci Mango
    Oct 2005
    Bowie, MD
    Quote Originally Posted by usmcdevildog View Post
    #1 I had the power steering High Pressure hose replaced because it was leaking through the hose
    #2 You might try snugging the pan bolts. The torque on the bolts is not very much, they might be slightly loose. Be carefully, the proper torque is not much more than snug, you don't want to over torque them and ring them off or cut the pan seal
    #3 you might take a close look to see if the electrical connector O ring is leaking. Fluid will run down the right front of the trans, maybe looking like it's leaking from the lower engine bolt or bellhousing.
    Hemi Wagon's Avatar
    Jul 2008
    MD
    Not too bad ..would be a good time to change out the verter for a nice stall
    Silver Bullet
    marshall9779's Avatar
    marshall9779 is offline MOPAR muscle baby!
    Mar 2008
    Gaithersburg, MD
    I had a leaky connection where the hight pressure line came off the pump. Dealer replaced under warranty.
    2010 Nissan Xterra S
    Sold:2006 R/T: JBA catback & headers, K&N Aircharger CAI, Diablo Predator 91CAI Tune, 180* Tstat, Cabin Filter Kit, hood struts, Daytona grill and emblem,Daytona rear R/T badge, Daytona Chin Spoiler,BT catch can, BT MOPAR hood emblem, BT R/T Engraved shift bezel, BT Shift Stick. - 305 RWHP & 344 RWTQ - pre shorties.
    1/4 Mi. 13.57 @ 102.73mph
    Chronic01505's Avatar
    Chronic01505 is offline I'M THROWED
    Sep 2007
    Maple Grove MN
    he hasnt changed his oil in 20k miles ^^ wow!
    2005 Dodge Magnum RT (RED)
    Features: Auto Lights, Chrome Vent Fins, Platinum Spark Plugs, MyGIG. Uconnect (08 LX Mirror) Alpine Solo X, Alpine 2000W Amp, Alpine 1000:1 Amp, 2 Rockford 500k- 1 faret total Cap
    Future Mods: 2Way Remote Start, Removal of the Roof Rack, (for sale if anyone wants it pm me) Superchip (not sure what one)
    Nov 2007
    Minneapolis, MN
    Quote Originally Posted by Chronic01505 View Post
    If you notice I said it was the first time I changed it since I owned it...I've only had the car 2 weeks.
    I did take it to the dealer, they are replacing power steering hoses. They said they put some dye in the oil but didn't find any leak. Now I've never seen any fluid under my car while its been parked in my garage. But how would you explain the fluids I'm seeing on the bottom of the engine? I am definately not seeing things.
    03ramit1 is offline LX Guru
    Sep 2007
    is it possable that whoever did the oil change before you looked under the car spilled some and you are seeing what is left over from that. oil has a funny way of traveling long distances in 80 MPH winds. there could have been a little oil on the drain plug and it was blown to the bell housing. oil spilled when filling the motor could have rundown and got on the oil pan bolts. just clean it off really good and keep an eye on it. if there are any new leaks then i would start to see where they are coming from. untill then there is no cause to panic.
    Retired from the Hemi world.
    Shane B's Avatar
    Shane B is offline Shane B
    Whittier California
    Quote Originally Posted by 03ramit1 View Post
    x2
    Nov 2007
    Minneapolis, MN
    Pan bolts were loose, re-torqued. Thanks for the input.
    formerice's Avatar
    formerice is offline LX Guru
    Dec 2004
    maine usa
    Minor oil leaks= free rustproofing! I'm from Maine,capitol of the salt belt, actually a lot of people spray used oil under their cars as rustproofing. Not recommending , but people do it.
