I've just had exactly the same thing after an oil change and still have the same oil pressure readings as you. I picked up a spare oil filter and ordered a new oil pressure sending unit just in case. As my oil pressure was still reading OK I disconnected the battery in the boot for 10 minutes and put my foot on the brake for 30 seconds to fully drain the power from the system. Connect back up and code's cleared and engine check light now staying off. If the code returns I'll swop the filter and pressure sensor and take it from there. Might not be the right way to do it but it worked for me.
Al
Link to my thread, same issue
Magnum 5.7 P0524 code help please
07 Magum R/T
57 Chevy 2 door hardtop
