I was just changing my low beams and had to remove my cold air intake. When I took it off I noticed there was motor oil in the tube. Is that normal? There wasn't any on the throttle body side though....
Sent from my DROID BIONIC using Tapatalk 2
GTP Stage 2 Heads
Sparrow Cam
Custom Johan Tune
Full 6.1 Exhaust
Catch Can
180 T-stat
Eibach Pro Kit
AAC Rear Wing
SRT8 ?
There is a baffle in the filler neck on the SRT8 intake, if oil is poured in quickly when refilling after an oil change it can run into the tube and then down into your CAI tube.
Nope a C and its been several thousand miles since the last oil change.
It's normal. When you nail the throttle the PVC valve shuts down. Crankcase pressure has to go somewhere so it comes out the breather vent which is the tube attached to the intake after the filter. In extreme cases where the blowby into the crankcase is high because of worn rings, even when the PVC is running it can't keep up so.....excess blowby goes out the tube as well.
Pedator, CAI, MDS indicator, ESP/BAS defeat switch, Tranzformer, blacked out wire mesh grille, smoked and flashing side markers, 9005 2400k 65W fogs, Euro rear fogs, debadged and demolded, 255/45/20 Nitto 420's, Boss 338 wheels, painted calipers. Glovebox & cup holder LED Mod. Blastin Bob 6db reso delete pipes. Euro LED side signal repeaters, 55/35 window tint, BT catch can. Color matched tail lights. Custom front lip. LED interior lighting.
Next: Lower with BCR Coilovers.
Awesome, I had an inkling that's what it was but better safe than sorry. Thanks ehh!!
