Results 1 to 6 of 6
    shane93nc's Avatar
    shane93nc is offline HemiTime
    Charlotte,NC
    noticed ticking when first starting up.
    When i got off work yeserday I cranked the Magnum and I noticed a ticking sound from the motr for about 5 seconds then it went away.It sounded like it needed oil.But I checked it and its fine.I have heard this noise before.Any concerns?With this being a newer car and and suck I don't think thats the noise i should hear.I have heard about the "Hemi tick".I hope that isn't what that is cause to be honest,itsa kinda imbarrasing having it when cranking up the car.
    lafrad's Avatar
    lafrad is offline Zomg.
    Feb 2004
    Muskego, WI
    Someone else talked about this... somewhere else:
    Is there a FRAM oil filter on there?
    I have had and heard bad experiances with oil flow on startup from fram filters.
    mhigham's Avatar
    mhigham is offline LX Guru
    Feb 2007
    Michigan
    You want the HEMI, you get the tick. Merry Christmas from DCX.
    Mike
    06 Magnum R/T Midnight Blue
    bipto's Avatar
    bipto is offline Daytona 500 bound!
    New Hampshire
    Agree with lafrad - if it quiets down immediately after startup, this is probably an oil filter check valve issue. The 5.7 Hemi tick is a constant...
    The Iron Mistress Galleries
    R.I.P. Dave...
    HemiLover's Avatar
    HemiLover is offline LX Guru
    Sacramento, CA
    yeah, it's gotta tick!
    Click the sig for mods and pics....
    lxcoded's Avatar
    lxcoded is offline LX Newbie
    It's really the oil filter. It already happened with my friends' oil filter. He checked on his Mazda Miata parts like its engine and everything was fine but not the oil filter. It had some damage on it that must have caused the ticking sound.
    bored...
