Results 1 to 15 of 16
    cadzilla74's Avatar
    cadzilla74 is offline Does this smell like chloroform to you?
    Jun 2005
    FTW TX
    Need help with an odd one
    So I go to check my oil and the top plastic ring of the dipstick just snaps off. What is still in the tube is below the top lip and I can't get a grip on it with anything. Obviously the oil jockey at my dealer jammed the sucker way in last week when I had the oil changed. Any ideas on how to remove it so I can replace it? I'm currently waiting for some Crazy Glue to dry to see if it will hold long enough for me to pull it out but I don't think it will work. The sucker is really jammed in there and the plastic didn't break off cleanly either .... what a stupid design.
    Super T's Avatar
    Aurora, IL
    Can't get in there w/ super skinny needlenose or anything? What about like a bolt extractor, those bite pretty good and the twisting would probably help loosen the dipstick??? Otherwise, I'd say wait til you change the oil next (or do it now), just remove the tube and ram something in it going the other way. Tube comes off w/ a couple easy bolts.
    Twisties's Avatar
    Twisties is offline Got Rope??
    Diging a hole in the desert
    Shop vac and seal it around the tube.
    or take the PCV valve out and use compressed air to pop the stick out.
    Before you criticize someone, you should walk a mile in their shoes. That way when you criticize them, you are a mile away from them and you have their shoes.
    "Those that beat their swords into ploughshares will plow for those that did not."
    "There are four boxes to be used in the defense of liberty: soap, ballot, jury and ammo."
    Quickbee624's Avatar
    Quickbee624 is offline Don't make me do crazy eyes!
    May 2005
    Middle Tennessee
    Have had this happen before in the past. Use some picks, needle nose pliers, and patience most of all. They can be stubborn sometimes.
    Dantra's Avatar
    Dantra is offline I shaved both of our asses
    Dec 2007
    Indiana
    I'm trying to picture what you have left.
    Is there still some plastic left in the tube that is attached to the actual stick? Any way to possibly get a wood or self tapping screw to start into it and then pull out?
    Chronic01505's Avatar
    Chronic01505 is offline I'M THROWED
    Sep 2007
    Maple Grove MN
    Get a new engine. Sounds pretty totalled to me. :D jk
    Take it to the dealer... Drive right in to that service garage. They have a tool that can pull that out. That happened to a guy in the past. I can't find the thread.
    2005 Dodge Magnum RT (RED)
    Features: Auto Lights, Chrome Vent Fins, Platinum Spark Plugs, MyGIG. Uconnect (08 LX Mirror) Alpine Solo X, Alpine 2000W Amp, Alpine 1000:1 Amp, 2 Rockford 500k- 1 faret total Cap
    Future Mods: 2Way Remote Start, Removal of the Roof Rack, (for sale if anyone wants it pm me) Superchip (not sure what one)
    TheBeastMaster's Avatar
    TheBeastMaster is offline Does it look like it's got a Hemi?
    Jun 2008
    Georgia
    You could also try a hemostat, which is the clamps doctors use to clamp blood vessels. They're like extremely narrow, light-weight needle-nose pliers. I have several and I can't tell you how often they've saved my butt.
    What we're dealing with here, is a complete lack of respect for the law! Speedfactory Stage 1, Zoomers,Airaid-S,BT,Grip,Sportwing
    MAGFX is offline Nevermind my mind!
    Dec 2005
    Arizona
    As a last resort, you can pull the dipstick tube part of the way out and push the dipstick out from the bottom. Undo the bolt on the side of the block (from underneath) and the two bolts that hold it to the valve cover. Good luck.
    I smile because i have no idea whats going on.
    My friends call me JONN (usually).
    cadzilla74's Avatar
    Jun 2005
    FTW TX
    Thanks for the replies. The dipstick tube is going to have to be unbolted as suggested. What's left of the dipstick is jammed in hard, the top of it has nothing to grab onto and is below the top lip of the tube itself. The glue didn't work, it stuck pretty good but the dipstick was stuck harder. I don't want to bend or distort the tube and didn't want to try drilling it out for fear of going too deep and pushing a bunch of crap down the tube into the motor.
    I'll hit the dealer's parts department tomorrow for a new dipstick and then try to get at it from the bottom.
    CtCruzer's Avatar
    CtCruzer is offline YEAH ITS JUST A V6
    Feb 2007
    WALLINGFORD CT
    Quote Originally Posted by cadzilla74 View Post
    dont buy new stick just call billet tech and get new alum dip stick handle
    tell them your in rush and im sure they'll get it to ya fast , then pull apart
    http://www.billettechnology.com/Merc...Dodge-Chrysler
    cadzilla74's Avatar
    Jun 2005
    FTW TX
    Quote Originally Posted by CtCruzer View Post
    Thanks for the heads up. I hadn't seen these before.
    Fargo59's Avatar
    i bet they kinked the dip stick. i had an issue with mine at one point, straightening out the stick fixed the binding. take the tube out and all should be happy again.
    FloridaRT's Avatar
    Ocala, Florida :-)
    Take a scrap piece of long, narrow metal with a hooked end and heat it up until it is glowing red.
    Push it into the plastic part that is stuck in the tube, let it sit until cool.
    Use some pliers to pull/twist out the plastic plug.
    Bob
    drumlugr's Avatar
    drumlugr is offline Haulin' Around That Great Gretsch Sound
    May 2005
    Ontario, Canada
    I had the same thing happen this past summer. Got the old dipstick out by running a short screw into the plastic. Pulled it out with pliers without getting any plastic debris in the engine.
    Dec 2005
    Arizona
    Quote Originally Posted by FloridaRT View Post
    Bob
    Ah, good one!
    And the BT dipstick handle is a good one also, that is if the metal blade of the dipstick is not broken.
