Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By richierevs
Thread: MSD Coils on 06' 5.7L?
    345 RT's Avatar
    345 RT is offline LX Padiwan
    Hollywood, CA
    Hey Y'all,
    Has any one put the MSD coils on there 5.7L yet? If so, do you see any differance in function,power,torque, or effinciancy?
    Geting them installed this weekend, and was wondering if any one else has tried this set-up.
    THANKS
    SON
    First LX Forum Member To Hit The 12 second Mark In The 1/4 Mile With A 5.7L Motor. Period.
    12-16-05@L.A.C.R. Palmdale , 12.947@106.08 ET, 1.909 60ft, 10.770 1000ft and .002 RT at 50 degrees
    Mods at time of run-GSM NOVI-1200 S/C SYSTEM, Dyno-Teck Long-Tube Headers, High-Flow Cats, a Borla Cat-Back System, and 18 inch BFGoodrich Drag Radials. L.A.C.R. R.I.P
    SIMPLY SOUTHERN
    mexi's Avatar
    mexi is offline thats my sippy cup!
    Feb 2006
    N Misssisspi . Memphis TN
    narc300c has them on his
    2012 Superbee SRT8
    11.928 @ 113.79 canned 93 tune corsa catback and dr's
    richierevs's Avatar
    richierevs is offline I Need DRs Really Bad....
    Mar 2008
    Stamford, CT
    IME MSD coils produce over 2X the ignition voltage of stock coils--means hotter spark. To get the most out of the coils consider using copper core spark plugs with platinum tips that are 1 heat range cooler than stock. The spark plug gap can be .050 (stock gap). You may also want to assure that the engine runs between 170-185* to reduce the chance of knock retard. Lastly, you want to consider upgrading the big 3 grounding cables to optimize coil recharge time.
    westeuro likes this.
    345 RT's Avatar
    Hollywood, CA
    Quote Originally Posted by richierevs View Post
    richierevs Dude,
    Thanks for the feed back.
    I have the ngk shorties for the blower. Will those work? I also have a 180* thermostat, will that work too? Or do I need to change plugs, or get a 170* or 180* thermostat? It seems like you know your stuff about cars. Youe help is much appreciated
    THANKS
    SON
    richierevs's Avatar
    Mar 2008
    Stamford, CT
    Quote Originally Posted by 345 RT View Post
    richierevs Dude,
    THANKS
    SON
    The NGK shorties are fine for the S/C and the stock coils. Adding the MSDs you'll want to go 1 heat range cooler than the shorties.
    Using the NGK shorty as a guide (SRT8 stock), get an Autolite or Champion racing plug (copper core with platinum tip) that is 1 heat range cooler (this would be 2 heat ranges cooler than your stock RT plugs). Gap the racing plugs as stock (.050).
    Because of the extra heat, get a 170* TSTAT (I personnally run a 160* TSTAT), and add 2 bottles of Water Wetter to your radiator overflow tank (if there's room). Using your Predator, change the fan speeds to 175* (low) and 190*(high)
    At a minimum upgrade the battery ground cable in the trunk to an 0/2 gauge cable. The best setup is to ground the heads with 0/2 gauge wire, to reduce throttle lag, but you can wait on that.
    I hope this helps.
