I got this off a Dodge Truck forum under the super charger section, anyone want/able to test this theroy out?
The "key trick" allows you to bypass the speed limiter while driving. You turn the key forward ( like starting ) and you can then go above the 100-105mph computer limit. This will temporarily kill your speedometer and the ABS light will come on.
Or you can pull the ABS fuse out and bypass the limiter, ABS light will be on.
