Results 1 to 15 of 18
    PlainAndSilver is offline LX Newbie
    Jan 2008
    JBA Header Install for 5.7 - Questions
    I just purchased some used JBA Shorty Headers for my 5.7. They are not coming with bolts or gaskets.
    Do I need to purchase new bolts or will the stock ones work? If I need new bolts, where do I get them - from JBA? The dealer? I have heard that Mopar gaskets are good to use - I assume I need new gaskets as well - do I just order new stock gaskets from the dealer?
    As far as install goes - can anyone let me know how difficult this is and how long it should take? My father in law is a mechanic and he has his own shop with a lift. He also put the JBA Shortys on my old SXT in about 3 hours. Is the install similar on the Hemi in terms of complexity and time to do?
    Any help is appreciated! Thanks!
    Predator 93 Tune/Tinted Windows/Mopar Hood Struts/Demoulded/180 T-Stat/Eibach Pro-Kit/BT Catch Can/BT Underhood Kit/BT Ported Throttle Body/ARIA CAI/JBA Hi Flo Cats
    Hemi31's Avatar
    Plattsburgh,NY/Lorain Oh
    order 6.1 manifold bolts,get a 1" steel sleeve to reuse 1 stud from the 5.7 manifold for the oil dipstick tube.Go get new 5.7 manifold gaskets from the dealer.....JBA gaskets are terrible.will take anywhere from 6-10 hrs for the install .
    RIP NHDave
    65standard's Avatar
    65standard is offline Programmer/Fabricator
    Dec 2008
    Chicagoland
    ^^^Exactly what he said^^^
    Jan 2008
    Quote Originally Posted by S/S Dodge View Post
    Thanks for the info. I am not sure what you mean about this: "get a 1" steel sleeve to reuse 1 stud from the 5.7 manifold for the oil dipstick tube" - can you elaborate?
    Also would you recommend pulling the heads or will this not be an issue since I have a lift to use?
    marshall9779's Avatar
    marshall9779 is offline MOPAR muscle baby!
    Mar 2008
    Gaithersburg, MD
    Quote Originally Posted by PlainAndSilver View Post
    The JBA kit comes with a 1" long by about 1/2" diameter steel sleeve that spaces the dipstick bracket out so it will the in the same location. The dipstick attaches to the stock manifold, and the stock manifold at that point is a lot thicker than the flange on the JBA header. That is why you need the sleeve, and you reuse the stock bolt in that bolt hole location. Ive heard pulling the heads is easier, and a little quicker. If you choose to go that route, you'll need new head gaskets, bolts, and anti freeze, and should doa n oil change after.
    If you do it with the heads on it is a hell of a job. It took me a good 7 hours on a lift and then another 4 on jack stands. That includes moving the car and getting set back up. Just make sure you double check every bolt. I missed one that was started and cross threaded. I had a guy helping me and didn't check his work. Good luck with the install. Go to JBA's website and get a copy of the instructions. I've heard you can do it without removing the motor mounts, but I couldn't get the heat shields for the stock manifolds out without doing so. If you can, that it will be a much easier job.
    2010 Nissan Xterra S
    Sold:2006 R/T: JBA catback & headers, K&N Aircharger CAI, Diablo Predator 91CAI Tune, 180* Tstat, Cabin Filter Kit, hood struts, Daytona grill and emblem,Daytona rear R/T badge, Daytona Chin Spoiler,BT catch can, BT MOPAR hood emblem, BT R/T Engraved shift bezel, BT Shift Stick. - 305 RWHP & 344 RWTQ - pre shorties.
    1/4 Mi. 13.57 @ 102.73mph
    TheMoparKid is offline LX Padiwan
    Anywhere but here.
    Once again, Erik is spot on.
    Our input is only so valid because we can do it pretty quick but the lift is the only true factor that helps. Otherwise, a set of skinny arms like my own help alot lol.
    Jan 2008
    Thanks for all the help so far - I really appreciate the input.
    I called JBA today about the spacer and they said they don't sell the parts individually. Does anyone know where I can get the spacer from?
    Also, in addition to the 6.1 bolts I know I need, the JBA manual also lists the following hardware as included:
    (4) 3/8 x 2 _ bolts
    (8) 3/8 flat washers
    (4) 3/8 lock washers
    (4) 3/8 nuts
    Does anyone know if I also need the above bolts/washers/nuts or can I reuse the stock ones?
    Thanks!
    Mar 2008
    Gaithersburg, MD
    You will need those. The 3/8 bolts and nuts are for the header to mid pipe connection. The stock manifolds have studs built into the flange, so those go with manifold when you remove them.
    sfeld02 is offline LX Newbie
    Apr 2009
    Marysville, KS
    Here was my experience.
    -note: I also used 6.1 bolts, mopar gaskets, and nordlock washers.
    http://www.300cforumz.com/showthread.php?t=65173
    Jan 2008
    Quote Originally Posted by marshall9779 View Post
    Great explanation! That makes sense - thanks for the info!
    ezridr95's Avatar
    ezridr95 is offline Air bag test dummy....
    Dec 2006
    Costa Mesa, CA
    I installed my JBA headers last year and just replaced the gaskets with Mr. Gasket ones, blew-out both rear cylinder on the JBA gaskets, don't waste your time. Put the good ones in now.
    Jan 2008
    Quote Originally Posted by sfeld02 View Post
    Good info! Thanks for sharing!
    The Unabomber's Avatar
    The Unabomber is offline LX Padiwan
    Aug 2007
    Cybertron
    What size Nordlock's do we need for the 6.1 bolts? Also I read that you had to run a tap into the heads due to the bolts binding. What caused this? Where the threads chingers/striped? Or was there a bunch of crust/junk in the threads from assembly, possibly thread locker?
    HerDaytona's Avatar
    HerDaytona is offline Wifeys Grape Ape
    Dec 2007
    Where it's Warmer
    The stock 6.1 bolts have threadlocker on them over the parts counter.
    Jan 2008
    Thanks for all the help and info so far.
    The only part that I can't locate is the 5/8 x 1/8 dipstick "spacer". Does anyone know if one of these can be easily made out of something, or can someone post a picture of what it looks like?
    Or if anyone knows where I can order this please let me know.
    Thanks!
