Results 1 to 11 of 11
    kudasai's Avatar
    kudasai is offline medium pimpin
    Oct 2004
    an jung ri, south korea
    interesting bas light....dodge concedes
    well, looks like i am keeping the car for now. i had one last bug to shake off it and make it perfect, and then my girlfriend was going to drive it for me if no one bought it.
    but now the issue. it has baffled me for 10k miles and dodge has refunded my service money and said sorry, but no clue. so maybe someone here can help.
    about 35k, the bas light popped on. i noticed no loss of power, no loss of any electrical system, and the antilock brakes and traction control still funtion properly. the light would come on and off from time to time, sometimes when i hit a bump, sometimes when i turned, sometimes going slowly over somthing at an angle. movement would make it turn on, and would make it turn off. and that seems to be the only constant.
    i replaced the wiring plug in the column at the advise of fnkychkn, and to my delight, the airbag light went out, to my dismay however, the bas light did not. i then replaced the clockspring due to my inability to seat the column shroud right the first time, and still no luck.
    so off to the dealer. the dealer hooked it up and it read multiple codes. he told me it was the scm. i told him i didnt think so, because the codes would clear themselves from time to time. however, he insisted, so i let them change it. they call me back to tell me car was done. i went down there, hopped in, and got halfway out the parking lot when "BING", and there it was again.
    they hooked it back up, and it was throwing the same codes. they tell me the part was bad. now at this point, i am having serious doubts, due to the nature of the whole thing. but fine, i tell them to change it, and i'll be prepared to talk more with them when the next one fails.
    which it does before i can even make it to the dealership to pick up the car. now at this point, i am getting miffed, due to the fact that it has been two weeks and no one seems to listen to what i am telling them. matters get worse when the service manager implies that my amp is the problem and "you shouldnt mess with the wiring on these things." not only do i tell him that the only thing hooked to the wiring is my clips on the speaker wires, power line from the batt and fuse for the power on, but that i reviewed the tsb dodge produced about how to install aftermarket equipment on the r/t's. i also brought up the point that i installed the stereo at 8k's and the car was fine for 27k after that.
    i was then told that dodge had faxed them a measurement for the steering column, and that they were testing the airbag module.
    today, i picked up the car, and was told sorry, everything checks out, and they have no idea how to fix the car. to apologize, they are going to refund my money for the scm that i had installed.
    so now here i am. my guess, i have a bad wire and/or connection. tommorrow, i am going to start going over everything with a multimeter and a test light, starting at the fuse box and working forward until i have touched and probed every wire and connection in the car.
    but if anyone has experienced this, i would love to know. i have searched and found many threads like it, but none that seem to be this.
    anyway, thanks in advance if anyone can help.
    later, jess
    05 magnum rt
    83 300TD with waste veggie kit
    92 nighthawk 750.
    burn vegetable oil to work, burn rubber on the weekends!
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Maybe check the plug under the console.
    BFNY PERFORMANCE
    RIP My Friend
    Guest Guest
    After a dyno pull my ESP/BAS light came on and we had to just pull the plug to reset it. Turned the car back on and after driving for about 1000 feet the light went off.
    Sounds like a ridiculously simple solution after all you've been through, but often times the simplest solution is the one overlooked.
    fnkychkn's Avatar
    greasy cardboard box
    Quote Originally Posted by kudasai View Post
    ...and it was throwing the same codes...
    can you post the codes?
    this is probably the worst approach to solving this problem you could ever take. it might be the approach they took, along with throwing parts at it, that has provided such poor results. first you need to figure out all the possible reasons for this fault and eliminate them one at a time. sometimes the act of disconnecting-reconnecting components can temporarily mask symptoms and derail the diagnosis.
    i sincerely hope we can help you out.
    boggart's Avatar
    boggart is online now aka MagnumSXT
    Pittsburg, KS
    That's awful that they just gave up. I'm sure fnky will stick with you though until you have a resolution. Might take longer over the net, but fnkys da man.
    Smoove06CSRT's Avatar
    Smoove06CSRT is offline Kiss my Rims.. They gots BIG lips!
    Nov 2005
    could it be that accelloramater (sp) under the console?
    2006 300cSRT8
    Fastest color...... Bright Silver Met.
    "OHH! A Strip Club.....I'll Get my sweat pants on!"
    kudasai's Avatar
    Oct 2004
    well, i'm off for nashville this morning. i will try and get the list of codes from dodge when i get back on saturday.
    05 magnum rt
    92 nighthawk 750.
    MomsR/T's Avatar
    MomsR/T is offline Builders of the 500rwhp 426's
    Houston
    TWIST3D BLACK MAG's Avatar
    TWIST3D BLACK MAG is offline GEORGIA LX CLUB
    Columbus, Georgia
    Quote Originally Posted by MomsR/T View Post
    I hate to say it, but watch it be a bad ground!
    Seeing that "motion" is causing the problem......I would Agree......
    Custom Signature by Hazman
    Georgia LX Club:
    kymag's Avatar
    kymag is offline LX Padiwan
    Dec 2005
    They ordered and installed a new sensor for my car and the light went out. I think there was a list of about 14 things for them to check and after the service man had checked all of that he said it had to be a sensor. I can check my work order and see which one it was.
    boblom is offline LX Newbie
    Nov 2006
    did the dealer do the simple plug and replace parts trick. #1 check to see if your tracton control switch is bad. It could have a bad conector the shakes to turn on the bas light on and off. BY MAGIC. My light came on after a long power burn out. it trigered my ABS secor and I neededto pull my batt. cable in the trunk to clear hal. good luck its allways the simplest thing that wants us to beat our heads against the wall
