got this off the chargerforums site - is this accurate - should i try it? any chances of damaging anything?
Step 1:
Open the hood of the
vehicle and open the covered fuse box on the passenger side of the vehicle.
Step 2:
Remove the following fuses and set them aside:
11; 14; and 16
These are labeled on the underside of the fuse box cover in a mirrored-layout fashion.
Fuse 16 is a Dark-Blue 15amp fuse found on the far right of the box
Fuse 14 is a Beige color 25amp fuse
Fuse 11 is a Neon Yellow 20amp fuse
Step 3:
Insert your key into the ignition and turn the key to ON. Wait for the initial sequence of lights and chimes to complete. Do not turn the key off until you have reached Step 5.
Step 4:
Without turning the key to 'OFF', turn the key to the 'START' position and hold it there until you hear a single chime. The engine will not attempt to start, this is completely normal. After the chime, release the key from the 'START' position back to 'ON' without cycling the key.
Repeat this step one more time, turning the key to 'START' and holding it until you hear the chime. Once the second chime has sounded, cycle the key back to the 'OFF' position and remove your key.
Step 5:
Return to the fuse box under the hood and reinstall the fuses, paying close attention to replacing the correct fuses to their original location. Close up the box, and start your car.
You have no completely reset the PCM's adaptive memory, as well as cleared any stored Diagnostic Trouble Codes (DTC's).
