Well.... I took my Magnum in to get the PCM flashed. (I used the rough idle excuse)
They flashed the PCM to the latest version. I immediately checked and the CCN ver. number available in the EVIC didn't change.
I did a very nice little burn out at the first light that gave me an opportunity. The acceleration seems a little bit improved and it also seems to be shifting a little more solidly.
One definate change I have seen is in fuel economy. I am quite a lead foot and usually hover around 11 or 12 in city driving. Right now, with lots of testing of the new found power and shifting I am seeing 14 mpg.
We are going on a longer road trip tomorrow so I should be able to see just how much improvement there is in the fuel economy then.
I am very happy with the PCM flash and recommend that anyone who has build date before 2/05 upgrade to the latest firmware as it seems to make a big difference. I think either rough idle or poor fuel economy complaints will get you the reflash.
well I ordered a glove box light switch while I was there. I specifically stated that I was having a rough idle. The stupid service writer was like "the idle is computer controlled and not adjustable." I was sitting there "yeah I know, that's why there's a TSB and a firmware update available through the starscan" so after two hours, basically they printed out what she said. I told parts guy I was going to cancel the order cause the service writer's being a bitch so then he comes back a minute later with the actual tech that worked on the car. He says they hooked it up to a router and ran the scan for updates and it didn't find any, just one DTC for an incompatible CD in the Radio and they did the ETC relearn, which he says is done through the starscan also. He also assured me that if there was any updates he'd want to do them since they get 1/2 hour of labor for something that takes him 5 minutes of time. He also said that if I can bring back the right TSB they'd punch it in and try to look it up.
