Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    moparman53's Avatar
    moparman53 is offline Finally got a HEMI again.
    Nov 2004
    E Williamson Co, Central Texas
    Question Getting code P0128
    As we stated in previous threads about my FRI mod (see my sig below), we got no codes right away. As a matter of fact, it didn't show up until the 4th day. I cleared it Wed. afternoon, and it came back this morning on the way to work. I'm not sure if it makes any difference, but I believe it was when it got to operating temp (coolant-wise). I think it may have something to do with the thermostat. If so, why did it wait 4 days? How can I keep it from coming back and keep the 180 degree t-stat?
    Carfinish's Avatar
    Carfinish is offline Capeeesh!?
    Nov 2005
    White Plains NY
    did ya read my thread on it?? if you get it you get it....it has to do with calcs the pcm does with ambient temp etc....even though others have no problems running the 180 tstat...yours may be getting stuck intermittantly...take it out and see if stuck or change the tstat and might clear the issue....let us know
    RIP
    12.869 @ 102.02 Stock 5.7 w/ C&L, Predator, JBA Cats, Volant catback, DRs & skinnies
    JimTurner is offline 300C Owner
    Mar 2006
    Orange County, CA
    I have the 170 RobertShaw. When my car is cold, I get it to operating temperature, the (using the EVIC display) goose the engine in 3rd for example, until the temp gets above about 181-183 for a couple of minutes. Sometimes if I am tired, and just driving lazily, I do not get the temp up, and get a CEL.
    jimt
    Cool Vanilla 2006 300C Build 09-05
    Hotchkis Swaybars / SRT8 Suspension
    Magnaflow CatBack (customized by MF)
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Just autostick it so it gets to temp faster.Once it hits 180* Throw it in drive.
    BFNY PERFORMANCE
    RIP My Friend
    moparman53's Avatar
    Nov 2004
    I don't suppose coolant level would have any effect on it, would it? I guess the car is hot; I drove it for 25-30 minutes at 65-70. The level on the tank is about an inch above the "Cold" line (facing the engine). Seems like it would heat up faster if it was low.
    So if I understand you guys; it's throwing the code because it doesn't think it's hot enough?
    gremlinsteve's Avatar
    gremlinsteve is offline Supporting Vendor
    Apr 2006
    yes, thats the basic answer. we can throw the stock thermo back in and get rid of that code.
    steve
    gremlinsteve, it does a body good!
    FRANK RACING INC.
    specialized cyl. head development for the 5.7 and 6.1 hemis.
    www.thehemisource.com
    Mar 2006
    Orange County, CA
    Quote Originally Posted by moparman53 View Post
    Yes, that is the cause of the code. As I stated above (and others did as well), put that sucker in autostick and force the temp above 180 after the intial warmup. No code after that.
    My car seems to have a lot more power running with the cooler t-stat.
    jimt
    moparman53's Avatar
    Nov 2004
    Quote Originally Posted by JimTurner View Post
    Yes, that is the cause of the code. As I stated above (and others did as well), put that sucker in autostick and force the temp above 180 after the initial warmup. No code after that.
    jimt
    Oh, she's got plenty of power. Today I slowed down to 20 to cross a RR track and nailed it. With ESP off (no pushee button and light off), it accelerated and then broke the wheels loose for a bit. I had to let off as my driveway was imminently approaching. This was on dry pavement. I still haven't had the nerve to take ESP off.
    Thanks,
    Kevin
    Hemi31's Avatar
    Meister said that his car eventually "Learned"the new T-Stat with the adaptives as well.I don't know how true that is but I live where it gets really cold and I have never thrown a code,I run a 180* as well....Had it out yesterday and it was 9* when I went to work.
    BFNY PERFORMANCE
    RIP My Friend
    mikeyb's Avatar
    mikeyb is offline Got Diesel?
    Jan 2005
    Tomball, Texas
    Mine did it several days ago when the temp got down to 30 degrees and it was icing. Had to pull fuse 11 to clear the CEL.
    MikeyB
    2005 Brilliant Black Magnum RT
    moparman53's Avatar
    Nov 2004
    Exclamation
    Quote Originally Posted by mikeyb View Post
    MikeyB
    About the same temps here. I cleared it Weds. afternoon and it came back after a day. Right now it's 41°.
    Mr. iNCREDIBLE's Avatar
    Apr 2006
    I've been getting this code running the 180 t-stat in this cold a$$ weather:
    my fix:
    I took one of my GF's nylons, cut the foot area off, and wrapped it around my CAI filter, haven't gotten the code since, I'll remove it once it heats up again...
    oh yeah, black nylon... so it doesn't look to bad...
    Hemi31's Avatar
    If you guys are all getting it now and are just getting some mild cold and I never get it,Meisters theory may be correct.
    BFNY PERFORMANCE
    RIP My Friend
    moparman53's Avatar
    Nov 2004
    Exclamation
    Quote Originally Posted by Carfinish View Post
    OK, finally got around to reading your thread. It has been cold lately, but it wasn't cold the first time it happened. It was about 65 or better. The T-stat is brand new. Supposed to be a 180 degree.
    What's the stock one, 210?
    Carfinish's Avatar
    Nov 2005
    White Plains NY
    stock is 190...what brand tstat...maybe someone knows some issues with it....maybe it is a faulty tstat...and opeing much earlier...could be?....I know somewhat simple device...yet
    try gettin a diff brand 180* and see what happens
    RIP
