I am looking for fuse 11. Its a dark blue 25, right? The fuse box cover is a bit confusing, so is it number one or two?
None of those lol. Its the yellow one. 2 over to the right from number 1 you have circled.
2006 Chrysler 300 Touring
It might be a 25 also, cause the newer models have 25's instead of 20's, just in case![]()
The owners manual says the yellow one is the Powertrain Module but I went ahead and pulled it anyway and now I have a ESP BAS error code on my instrument panel.
What is that?
Whats the reason you are pulling fuse 11?
Im a practical joker, so dont take anything seriously. GOT IT. GOOD.
Big Thanks to: | www.BilletTechnology.com | www.TVandNav2Go.com | www.VIP300C.com
A lot of ppl here say to pull it and then replace it so the computer is re-set and it will "learn" your driving style. I am the second owner.
We've pulled our fuse 11 twice ... and I absolutely love the results every time.
How long did you pull it for?
When I do this I somewtimes do it for about 10-30 min.
As a matter of fact I got a check engine light today and I pulled fuse 11 and it went away so I dont know why you are throwing a code.
Do you know what code you are throwing?
fuse 11 should only be pulled while key is off. do not turn key on until fuse 11 has been re-inserted. disconnect battery (while key is off) to clear the other DTCs.
Right, the key was out and I waited 1-2 minutes and put it back in. I then had a rough start and the ESP BAS light came on. So I did some research and a lot of ppl have that code but it goes away after cycling the engine.
I tried this and it did go away, but I expect it will return.
15 seconds is all that is needed. post #24 in this thread may help clear things up.
So ya know ... fnkychkn is THE authority around here. If he says to do it, do it. He knows these cars like no one else.
Here is my dummy question... I have flashed the computer with the Hypertec Power Programmer. Should I still pull the 11 fuse or will that really mess everything up?
Phil
Altus AFB, Oklahoma
2006 Maggie R/T
5.7L Hemi Registry # 00687
