Page 1 of 4 123 ... LastLast
Results 1 to 15 of 50
Thread: dyno heat heads
    kkd60 is offline LX Newbie
    Dec 2006
    dyno heat heads
    has anyone dynoed just the heat heads or hemi shop heads. I was curious as to what the results were. Mine are going on tonight, hopefully I can dyno tomorrow or thursday. I am also putting the 6.1 intake on at the same time. I already have the krc 218 cam and hedman longtubes.
    gremlinsteve's Avatar
    gremlinsteve is offline Supporting Vendor
    Apr 2006
    6.1 intake on a 5.7?
    steve
    gremlinsteve, it does a body good!
    FRANK RACING INC.
    specialized cyl. head development for the 5.7 and 6.1 hemis.
    www.thehemisource.com
    are you going with 6.1 heads too? did you start off with a 5.7 hemi?
    Apr 2006
    6.1 heads on a 5.7? nice compression bump but one hell of a port window.
    steve
    FRANK RACING INC.
    Dec 2006
    5.7 heads ported then port matched to the 6.1 intake.
    Apr 2006
    ok. good luck and let us know the outcome. im interested.
    steve
    FRANK RACING INC.
    FlyByU's Avatar
    FlyByU is offline MSHS
    May 2006
    Long Island, NY
    Didnt powerwagon do this also?
    MomsR/T's Avatar
    MomsR/T is offline Builders of the 500rwhp 426's
    Houston
    Quote Originally Posted by FlyByU View Post
    sort of; he has MOPAR heads w/ 6.1 intake. The windows are completely different shapes............
    Fast56k's Avatar
    Fast56k is offline I ain't no FRI baby!!!
    Mar 2006
    You can get a 6.1 intake for like $600 at the dealer with fuel rails, throttle body and even intake gaskets.
    C.
    Silver 06 CSRT-8
    Dec 2006
    http://dodgetruckworld.tenmagazines....f_61_intake_on
    Here is a picture. You can click on my profile over there and see the porting of the intake window. The 5.7 intake port is alot different, thats why I had it gasket matched to the 6.1 intake window. This is on a truck by the way.
    MomsR/T's Avatar
    Houston
    (in response to Fast) we understand that..............the issue is "does it fit" and how they accomidated the fit.
    Dec 2006
    http://dodgetruckworld.tenmagazines....n-335924-pos-1
    theres a picture of the intake ported to match the 6.1 intake gasket
    MomsR/T's Avatar
    Houston
    Apr 2006
    i always thought the port volume in the 6.1 was a little lower than the 5.7 had. maybe im wrong.
    i think i would have rather added some epoxy to the intake runner in that 6.1 and match up to the 5.7 port window.
    the 5.7 bowl and the 6.1 bowls are close to the same size btw.
    so many ways of doing it...
    steve
    FRANK RACING INC.
    MomsR/T's Avatar
    Houston
    The plenum area is so much larger I would have worried the low RPM torque would actually fall...........
    I would like to see epoxy added to the floor of the plenum...........
    We'll see..........
