Rev,
How could they increase duration? The valves would open farther in the same amount of time as before no?
Originally Posted by
Rev.Hammer
Another factor to consider is that you are limited by Valve to Piston clearance. Looking at what your gross lift would be, either you get custom pistons or....
Also higher ratio rocker arms tend to slightly increase off seat valve duration.
As of this time... I would find something else to eat up that 3500.00 that would make you happier....
