Results 1 to 12 of 12
    LiLbuddha is offline LX Padiwan
    Nov 2008
    beat to death but gotta ask
    ok well i have a 05 mag r/t
    id love to put my car into a high 12.9 or better just to say i got a 12 second wagon haha
    anyways plans so far are magnaflow catback, intake, thats about it
    ive only had this car for little over two months and just figured out my issues with the air ride so wanna work onto the motor now
    what are some suggestions?
    metgo's Avatar
    metgo is offline Life is too short to be driving slow
    St. Louis
    The best way to do it would be to add headers, heads and a cam. You'd be in the 12s easy. If you want to do it with out heads and cam you will need a lot of other stuff. Headers, catback, intake, predator, UD pulley and drag radials would get you into the very low 13s or maybe upper 12s with good air and some weight reduction. Gears would help out a lot, lots of people are selling their SRT 3.06 gear rear ends because they are swaping them out for getrags. So you could probably get a setup pretty cheap. Or you could just throw nitrous on there now and be done with it. It all depends on how you want to get there and how much money you want to spend.
    Quote Originally Posted by JusticePete
    Even bad pub is good for business.
    In my years of business I have found that there are three truths: the customer's truth, the busness owner's truth and the truth that lies some where in the middle. No additional commentary is required nor would it would serve no purpose.
    My Pedders Experience
    iceman-5076Hemi's Avatar
    iceman-5076Hemi is offline LX Padiwan
    Aug 2008
    Central Texas
    metgo...if one were to go the route of heads, headers and a cam or even juice, wouldn't it be very wise to beef up the bottom end?
    If not, at what point should you consider beefing up the bottom end, i.e. crank, rods, main bearings and or even pistons? Is there a HP/Torque benchmark you should not cross before spraying and or adding turbo / superchargers etc.
    Thanks to anyone that could help out.
    DODGE MAGNUM...its NOT your mammy's station wagon!!!!!
    2006 Magnum R/T, Borla Catback, True Cool Oil cooler, 170 tstat. Superchips, Volant CAI.
    Guages and piller pods coming soon!! (still working on getting them hooked up)
    metgo's Avatar
    St. Louis
    Quote Originally Posted by iceman-5076Hemi View Post
    It depends on how far you want to go. If want to really spray the crap out of your car all the time you might want to buy a different bottom end. If you just want to run head/cam and/or a small shot of nitrous you'll probably be fine with stock bottom end. If all you want to do is get in the 12s you can do that with as little as 350 rwhp. There is many 5.7 guys making over 400 rwhp with no issues.
    dudeiwin86's Avatar
    dudeiwin86 is offline Dude...
    Houston, TX
    there are cars running low low low 12's without doing the bottom end, there is no need to.
    unless of course youre talking big boost (over 6-7 lbs) or over a 125 shot of spray.
    heads and a cam do not require any modification to the bototm end unless you really want to get wild and run high compression pistons.
    without doing the bottom end... the max horsepower on motor you can realistically acheive is about 400-420 rwhp
    this is a rough number, depending on the dyno. but the fact of the matter is.... you cant really get much higher than that without going into the motor.
    people have heads + cam + spray and are seeing in the high 400's and low 500's, and the bottom end is just fine. the catch 22 is they have a rock solid tune and are not cutting ANY corners.
    i also know of 1 guy to add a blower to his heads + cam setup at about 5-6 pounds, and made about 520rwhp. stock bottom end.
    500rwhp is the mark where you have to start worrying about the transmission, not the bottom end.
    the problem with our bottom end is not taht it cant take high horsepower...
    its taht it cant take high heat.
    big boost or nitrous and the pistons just break.
    the rods and crank are damn good from the factory.
    heres what you need to get into the 12's on motor without breaking the bank
    headers, high flow cats, catback
    a cold air intake
    25% underdrive pulley
    camshaft
    springs, rods, install kit for the camshaft
    diablosport predator + custom tune
    torque converter
    drag radials.
    this is your basic track pack.
    if you want to really kick it up a notch and go for low 12s
    you can add
    heads,
    rear end (differential, axles, and depending which route you go, a limited slip or gear increase or maybe both)
    if there is ANYTHING i can help you with please feel free to PM me and i can put you in teh right direction
    MadMagnum77's Avatar
    MadMagnum77 is offline If it looks fast it better go fast!
    Dec 2008
    Miramar, Florida
    just add some giggle juice
    im running a zex 100 shot, and im on street tires, i have drag radials on the way and i know for sure i will be in the mid to high 12's when i head back to the track.
    you can have a 12 second Mag in around $1400 - $1800
    C&L intake and Diablo kit from RPM outlet $550
    Zex plug ang play kit RPM outlet $570
    Drag Radials $ price varies around $400 and up
    Remember, you can spend as much as you want, lol, its all a matter of how fast you wanna go!
    2005 Dodge Magnum R/T (13.122 at 106.83)- C&L Cold Air Intake, Diablo Predator 93/CAI tune, Zex 100 shot, ARC Bottle Heater w/ pressure regulator, 180 t-stat, Eibach Sportline Springs, Eibach Pro Dampers, 2006 SRT8 Charger Wheels, Yokohama 265 35 20.
    Nov 2008
    well heres kinda where i was gonna think about going,
    cai intake, magnaflow catback, diablo, zex 100shot
    does 25% underdrive help alot?
    metgo's Avatar
    St. Louis
    Quote Originally Posted by LiLbuddha View Post
    25% UD pulley doesn't help a lot but for the price it's a good hp to $$ ratio.
    Dyno Results: 25% Underdrive pulley
    Dec 2008
    Miramar, Florida
    sounds like a good plan, with some practice at the drag strip you will be in the high 12's
    with a good set of tires in the back and a solid launch you wont even have to try.
    good luck with the mods
    Phil
    Aug 2008
    Central Texas
    next question...sub frames? At what point do we want to put in sub frames or is our platform sturdy enough for #'s between 400-500 HP?
    sorry to be so ignorant, but I would like to have my baby pampered, but also an occassional flogging would be nice too, without damaging / warping the sheetmetal!
    Dec 2008
    Miramar, Florida
    from what i have read up on, there are guys on here running that kind of power and more and dont have the subframe reinforced, i dont see a reason to do it unless you are doing some serious power or just want a stiffer ride, but what the hell, it couldnt help.
    dudeiwin86's Avatar
    Houston, TX
    the only people doing any kind of subframe stuff is Razors Edge.
    even then, no 1 is using it because it is "needed" at at the drag strip.
    the people running 10's arent usign it that i know of, and part of the reason is because thse cars are so damn heavy, that losing any weight any how is good, and if you can avoid it, you dont want to add any
