Results 1 to 15 of 26
    done's Avatar
    Old Hickory, TN
    AWD on the 1/8th track
    I was out last night at Music City raceway, an 1/8th mile track up in the hills.
    Music City 6/12/2007
    RT----------- .3650------ .1340------ .2820------ .0510------ .2410------ .610
    60ft---------- 2.081 ------2.148 -----2.036 ------2.124 -------2.030 ------2.020
    330ft -------- 5.844 ------5.893 -----5.771 -------5.84 --------5.732------ 5.71
    594ft--------- 8.364 ------8.404----- 8.274------- 8.330------ 8.220------- 8.187
    1/8 time---- 8.931------ 8.968----- 8.837------- 8.890 ------8.779------- 8.744
    1/8 Speed- 79.38------ 79.74----- 79.94------- 80.35------- 80.54------ 80.80
    RPM---------- idle--------- 1250------ 1000-------- 1800------- 1000------- 1000
    Launch
    So for your guru's, what should have been my dial-in for the last run, considering the first 5 runs. Also note the change in 60ft times versus the launch RPM's
    Temp was 84 at the start, 82 at the end. The last two runs were after dark.
    MomsR/T's Avatar
    MomsR/T is offline Builders of the 500rwhp 426's
    Houston
    it shows you were picking up speed as the night grew cooler.
    An 8.79 wouldn't have been a bad dial in..........
    Are you spinning?
    done's Avatar
    Old Hickory, TN
    Quote Originally Posted by MomsR/T View Post
    Are you spinning?
    No spinning at all, just goes.
    MomsR/T's Avatar
    Houston
    I asked because one of your worst runs was on the 1800 launch.............would "assume" it was due to traction issues.
    I am suprised its not hooking any better..........
    What do the AWD cars weigh?
    done's Avatar
    Old Hickory, TN
    How can I get better "hooking" if I am not spinning at all?
    About 4400 pounds.
    I used an 8.79 dial in. As you can see by the last run, I broke out.
    MomsR/T's Avatar
    Houston
    I dunno..............thats why I asked.
    It would "seem" that something is wrong if you bring the RPM's to 1800 yet it goes slower..........
    I think the 8.79 was a good "guess".............I would have made the same mistake.
    However, when braket racing, I like to be up front vs chasing.........
    I like to have a half a car on the other guy then release off the gas the last 30 - 50 feet............
    RandomAccess's Avatar
    Monroe,NY
    the AWD cars bog a bit Lee. That probably explains the difference between the 1000 RPM and 1800 RPM launches.
    I seem to get better performance when I leave at Idle... but maybe I'll give the 1000 RPM a shot again.
    12.571 @ 106.71
    MomsR/T's Avatar
    Houston
    huh................bog?
    I wonder if thats a tune issue..............
    Wonder what a converter would do?
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Knowing the sun was going down and depending on how long the car sat I would have gone with a 8.6 something.....probably 8.69.Once you went 8.7 you should have dropped a half a tenth for the dial in.
    BFNY PERFORMANCE
    RIP My Friend
    boggart's Avatar
    Pittsburg, KS
    I agree, if I had just run an 8.77, no way I'd go with a .79 dial, maybe .70
    Great times for an AWD. Translated to 1/4 times, that should be 13.5's to 13.9's.
    Hemi31's Avatar
    Quote Originally Posted by MagnumSXT View Post
    I hope so.....Done ran 13.3's up here at Napierville last month.
    BFNY PERFORMANCE
    RIP My Friend
    MomsR/T's Avatar
    Houston
    Hemi31's Avatar
    If the Transfer casse and Front diff canhandle the torque a Converter would be worth a ton on an AWD.Maybe 3-4 tenth's.
    BFNY PERFORMANCE
    RIP My Friend
    done's Avatar
    Old Hickory, TN
    Quote Originally Posted by RandomAccess View Post
    what about my verter comment?
    Any thoughts?
    I don't really feel any "bog". It just keeps picking up RPM's smoothly.
    The last run was the breakout.
    How much would the labor be to change the convertor?
    By the way, I surprised the heck out of a 350Z on the fourth run. I guess he was not expecting to view my tailights at the 60ft. The other cars I ran were all older cars running for fun, except on the first run with a 7 second Nova.
    Monroe,NY
    Pretty big difference at the 60' though... a full tenth... Did it feel any different at all?
    Converters are about $1200+ out the door. Carfinish has a thread quoting specific prices... Folks on the East end up in Connecticut for the install.
    12.571 @ 106.71
