Results 1 to 15 of 17
Thread: 6.1 cam in 5.7
    Hemi Mag's Avatar
    Hemi Mag is offline Baba Booey
    Nov 2006
    Mississauga
    6.1 cam in 5.7
    I saw an listing on ebay for the 6.1 cam, his listing said that the Ram guys have been running it w/o problems in the 5.7. Question is will it work in an LX 5.7? He was claiming about 25 HP increase.
    AC
    TNCHARGER's Avatar
    TNCHARGER is offline A Confessed LX Modaholic
    Jan 2006
    Kingsport, TN
    6.1 Cam (used)
    2007 SRT8 Charger...in black...of course.
    LMI True CAI, American Racing LT Headers, Magnaflow HF Cats & Exhaust, Arrington SR-2 Cam, Tranzformer, Edge 3000 Convertor, Quaife LSD 3.55 Gears, 09 Half-Shafts, 185 Stat, Hotchkis Springs, Tuned By Arrington....More to Come....
    The 2nd Admendment
    Washington didn't use his right to free speech to defeat the British...he shot them.
    MadCharger's Avatar
    Apr 2006
    Huntersville, NC
    Quote Originally Posted by Neon Driver View Post
    AC
    Yep - it works just fine in the LX. The most computer friendly cam you can find for the 5.7, and you can't beat the price. The only problem is that most of the power is made up high in the RPM scale. Frank Racing has a cam timing tool coming out next month though, that will allow it to be advanced, and bring the power down into the lower range. If this does what it's expected to do, the 6.1 cam may be the best bargain out there!
    440 Stroker Short Block 4sale!! (tentatively sold)
    2010 MSHS Stroker N/A Champion!
    gremlinsteve's Avatar
    gremlinsteve is offline Supporting Vendor
    Apr 2006
    ive got some of the first batch finished in fact.
    steve
    gremlinsteve, it does a body good!
    FRANK RACING INC.
    specialized cyl. head development for the 5.7 and 6.1 hemis.
    www.thehemisource.com
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Hmmmm,Maybe put the SRT cam I take out into my AWD
    BFNY PERFORMANCE
    RIP My Friend
    MadCharger's Avatar
    Apr 2006
    Huntersville, NC
    Quote Originally Posted by gremlinsteve View Post
    steve
    Hey Steve - make sure you guys put my name on one of those, so I can pick it up on my visit down there on the 6th!
    Apr 2006
    these things are like doritos. crunch all you want, ill make more!
    steve
    FRANK RACING INC.
    razman131 is offline stuck in the Nwest
    Jan 2006
    Chula Vista/San Diego/Bremerton
    AC
    it will work though i dotn think your MDS will still work.
    2006 Magnum SRT-8
    1999 Dodge Dakota R/T CC(many mods... ask me)
    oldest Beater: 1990 Toyota Chaser (recycled)
    old New beater: 1989 Nissan Serena Van(also recycled)
    Mommy Mobile: 2004 Dodge Caravan SXT....
    newest beater: 1991 Honda Civic DX 4dr (sold for 3X more than i paid for it)
    lafrad's Avatar
    lafrad is offline Zomg.
    Feb 2004
    Muskego, WI
    If you are brave, get some good Valvesprngs and put the 6.1 cam in with the MDS lifters...
    MomsR/T's Avatar
    MomsR/T is offline Builders of the 500rwhp 426's
    Houston
    I suggest you NOT be brave and just run some 6.1 valve springs w/ this cam. This is fairly easy and inexpensive; this is what you need.
    6.1 cam: $80 - $180 used/new
    8 lifters w/ guides: about $90
    16 6.1 Valvesprings: about $75
    FRI Adj Timing Gear: $163
    B&G 5.7: $450 (?)
    Torque Converter: $350 - $450
    Drag Radials on R/T's: PRICELESS!
    Dan79 is offline LX Newbie
    Eugene, OR
    With the timing gear on both, which would be better? A Comp 260 or stock 6.1 cam. Pros/cons of each setup?
    2007 Dodge Charger SRT-8
    Current mods: SRT Max cam, Inertia Performance heads, aFe Stage 2 CAI, SLP underdrive pulley, MM ported throttle body, ported intake manifold, Paramount 4000 TC, Magnaflow midpipes with high flow cats, BT catch can, 180 tstat, Getrag rear, Zeitronix ZT-2, Hotchkis anti-sway bars, Razor's Edge shock tower brace. Installed by Troy @ Ding's Auto. Tuned by Johan.
    MomsR/T's Avatar
    Houston
    jury is out.................check out the MoFo where Meister's car went against Cool-V's.
    fairly close apples to apples...........
    I feel the difference is that once we can advance the degrees on the 6.1 we can bring the power back in the RPM where we can use it.
    Cool-V is about to advance his as well as MadCharger..................stay in touch and I can give you more percise numbers.
    BUT BUT BUT..................please remember that the 260 can use the MDS while the 6.1 can't.
    MadCharger's Avatar
    Apr 2006
    Huntersville, NC
    Quote Originally Posted by MomsR/T View Post
    But also keep in mind that the 6.1 will idle like stock, and be perfectly acceptable to HAL - in all weather conditions!
    Eugene, OR
    Quote Originally Posted by MadCharger View Post
    Are you implying that the 260 won't?
    MadCharger's Avatar
    Apr 2006
    Huntersville, NC
    Yes..... From what I've seen, the 260 will idle ok in the warm weather, but have a harder time in the cold. However, with a B&G flash, this is not an issue.
