Results 1 to 6 of 6
    da BoMM's Avatar
    da BoMM is offline Conspicuous Combustion . . .
    Spring, TEXAS
    5.7L Vital Signs
    Just checking with the rest and the tech guys:
    From my EVIC at IDLE:
    RPM: 600-630
    Engine Temp: 219 and falling (to 210 in about 1 min)
    Oil Press: 16 PSI
    All seem normal, but does OIL PSI drop this low?
    Also:
    Last Chime Req
    abs
    VMM 319
    Anybody know what the last 3 lines mean?
    6.1L HEMI #622 '07 TorRed MSRT8 1/165= TORRED >< 6.1L HEMI '10 Silver Jeep GC SRT8=4X4JET
    MSRT8 owners http://www.lxforums.com/board/groups/magnum+srt-8+owners/
    crazy_luck's Avatar
    crazy_luck is offline I know where Hoffa is...
    Belle Plaine, MN
    Quote Originally Posted by da BoMM View Post
    RPM: 600-630
    Oil Press: 16 PSI
    Also:
    Last Chime Req
    abs
    VMM 319
    The last chime was the abs check. VMM 319 is Vehicle Memory Module and the 319 is the version - this should ALWAYS appear (the version may change if the computer is reflashed).
    Oil PSI sis normally around 14~20 at idle, no worries there.
    06SilverSteel's Avatar
    Jun 2006
    Houston, TX
    yeah, the oil pressure is scary low...same on my dakota i had a couple years ago.
    da BoMM's Avatar
    Spring, TEXAS
    Quote Originally Posted by crazy_luck View Post
    Very cool -- thank you, man!
    Beans for dinner for you! lol
    MSRT8 owners http://www.lxforums.com/board/group.php?groupid=24
    Spali32's Avatar
    Spali32 is offline Spali32
    Nov 2005
    Puyallup, WA
    Oil Pressure
    I was taught that 10 psi oil pressure for every 1,000 rpms. So if you charger is idling at 600rpms then 16psi is plenty enough. I believe 10psi of oil pressure in an engine would squirt across the room 10ft or more.
    THE DETAILER www.spalisautodetailing.com
    Mods--AIRHAMMER CAI, Borla 125's, 180 Stat, Catch Can, Predator w/91 Octane/CAI Tune, ACES IV, 7.5w-23w oil, 75-115W gear oil, Quantum Blue tranny fluid. Best to date 13.7sec @ 102.52mph
    PaulFix's Avatar
    PaulFix is offline Mr. White Chocolate P. Rock
    May 2005
    BC, Canada
    Sound fine, I learnt with the 10psi per 1000rpm rule
    Dodge Magnum RT AWD MDH=Jan 19th 2005 7-8pm
    Tow package, Midnight Blue, Painted spoiler body colour, Auto headlights, HID lows, Fogs on with Hi beams, SC flash with custom tranny and 91 tune, RER MyGig installed, Tranzformer, Resonators deleted, Custom Stainless intake.
    160,000km driven very hard, repairs include replaced front brake rotors and pads $200, rear pads$, ebrake shoes, all 4 tie rod ends $50ea (only 1 was loose), front sway bar rubber bushings $25(first thing to check if front is clunky); 3m refinished headlights WOW $30, 4 sets of tires, 2 tranny filter and flushes,
